Weekend of fun in the sun with lots of new equipment
- Has thanked: 17970 times
- Been thanked: 8905 times
The weekend was forecast to be glorious and it certainly was, we had lunch out in the garden both days!! and it is only February! lots of wildlife has awoken with buds and blossom bursting, butterflies and bumble bees. I now fear if it goes sharply back to winter in March they will all be in trouble. I even found some frogspawn in the local pond this afternoon.
Anyway, Saturday dawned and it was clear, well sort of, full of contrails and white haze. So I decided that maybe the C11 wasn't worth trying out and I did want to see the big filament so I set up the Solarscope DSF-100. So I decided to try out my new camera ASI174M and try that out instead. At the moment my Grasshopper 3 is running at only 4fps and it is really annoying me. If I start up Firecapture, close down, unplug, start up again about 10 times I finally can get a run at 26fps. I thought that my USB3 socket was failing as it kept saying that it was running at USB2 speed. However, I tried the ASI174M and I can get up to 220fps in ROI no problem in Firecapture and in that same USB3 socket, so that rules that out.
I tried taking a full disc with the Solarscope but the resolution is very poor with the large pixel size of the camera. So I won't show it. I then used the 1.6x with the ASI and that was much better, but still not a patch on the level of detail I get with the Grasshopper. I really need to get the Grasshopper working and reserve that for full discs. So here is the full disc, probably better if you click on the link and view in Flickr. Seeing was very poor so I can't rule that out either.
2019-02-23 1-5x f colour by Alexandra Hart, on Flickr
2019-02-23 1-5x by Alexandra Hart, on Flickr
I then moved on to a 2x Barlow and the ASI174 seemed to really excel at this scale and considering the seeing was dire I was very pleased with the results. It is also interesting that using the 1.6x barlow the little tiny AR to the bottom left of the main region was very bright (plage), as soon as I added the 2x Balow all the bright plage disappeared as though this Barlow takes the Solarscope off band slightly? weird!
Sun_105207_23_02_2019 by Alexandra Hart, on Flickr
Sun_105207_23_02_2019 f colour by Alexandra Hart, on Flickr
Sunday, this was forecast to be better than Saturday so I had the C11 cooling in the garden. However it was thick fog until 11am, so I just had a very small gap to set up. Again the sky was very white and hazy but very calm. I thought I wouldn't stress and just have fun. So I spent ages with the hubby getting the telescope balanced, then with the new ERF on, getting that balanced too. We got there in the end.
Celeston C11 / Aries ERF / Lunt CaK wedge by Alexandra Hart, on Flickr
I then spent the next 30-45minutes desperately trying to find focus. I always hate this bit when trying new kit out. Finally I worked out that I had to have the Lunt wedge directly attached to the C11 and in as far as it can possibly go in. So it only just works. Seeing at 12-1pm over houses with white skies was never going to bring glorious shots but I did manage some images so I was extremely happy. I think they are far better than my TEC140 has ever produced with the Lunt CaK wedge
Sun_124746_24_02_2019 by Alexandra Hart, on Flickr
So a fun filled weekend and I feel very happy that everything seems to be working OK.
Re: Weekend of fun in the sun with lots of new equipment
Wow, that is a nice and sunny weekend. That Celestron is really impressive!
Had the same today with my PGR, 26 was my framerate too. I removed firecapture. Downloaded the new SDK. Installed FC again and got it all working.
- Has thanked: 20779 times
- Been thanked: 10462 times
Great shots Alexandra! I think we must have been taking the same closeup shots at the same time The new kit seems to be working well!
The latest SDK is the key, I did the same at the end of last week. Deleted the old one and installed the new one.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Great H-alfa images, Alexandra, really impressive, your Solarscope is a winner!
Raf
- Bob Yoesle
- Has thanked: 541 times
- Been thanked: 811 times
Very nice images Alexandra, especially H alpha!
I think we need to get Valery or Baader to address making a CaK spherical aberration corrector for the SCT, and the results will be even better!
- Has thanked: 9307 times
- Been thanked: 6144 times
Looks like you had a nice session, Alexandra ! The filament close up came out really well.
- Has thanked: 1188 times
- Been thanked: 1382 times
- Been thanked: 4422 times
Hi Alexandra...
Your Ha images are superb...rally love these FD shots, and the C11 CaK is very impressive...can't wait to see the results under better conditions.
Well done
Well done
Alexandra, congratulations with 11" + ARIES DERF first light!
Here is my take of the CaK image.
Next time try to stop down your telescope with 240mm mask and use TV 2.5x PowerMate to get better scale.
Also, for CaK image a ZWO ASI290MM camera is a must.
- 280mm-CaK-AHart-150%.jpg (264.7 KiB) Viewed 2104 times
Oh... I thinked about this many times already, but I am afraid there are too few potential clients for such a corrector. Of course, Venus imagers with their 12" and 14" SCTs may also be interested in this corrector, but I am not sure. Small series custom orders always expensive.Bob Yoesle wrote: ↑Sun Feb 24, 2019 8:17 pm Very nice images Alexandra, especially H alpha!
I need at least 50 clients to make this corrector profitable with a retail price of about $500. And it must have at least 3x power (to realize it's full potential in resolution) and coma corrected. HD scopes will need another corrector.
- Has thanked: 175 times
- Been thanked: 429 times
Just curious, can shifting the focus in either direction (i.e., pushing the primary mirror in or out) offset some of the spherical aberration in CaK? It would be a lucky coincidence if so. Or is there any stock item (eg, a Barlow) that has a roughly opposite aberration at this frequency that can be employed here? Again would be a lucky coincidence.
George
George
- Has thanked: 8543 times
- Been thanked: 8280 times
An excellent set of images, Alexandra. Fabulous FDs.
That’s a heck of a nice ERF cell on you C11
Thanks everyone for all the nice comments, tips and tricks
Yes Stuart, it is a heck of a nice ERF cell
