Hi all,
Here are two active acreas at the sun as seen March 6 2019 with SkyWatcher 150mm F/5 refractor, ARIES 150mm DERF, TV 2x Powermate, standard Quark Chromosphere, 0,7x reducer and Basler ASA1920-155 camera IMX174 chip.
F/43 at the etalon. Seeing was just average and good transparency at +14C.
4000 frames recorded in Fire Capture at 185fps, 4000frames stacked in AS2!. Processed in AstraImage Pro 3.0 and PS CS6.
Right click on the image and open it in a new window to see the image at a full resolution.
Thanks for looking.
Valery.
AR12734 March 6 2019. SW 150mm scope + Quark.
- AR12734-2019-March-06-UT08h-49m150mm-F43-ARIES-DERF-Quark.jpg (263.3 KiB) Viewed 865 times
- 2019-March-06-UT08h-51m150mm-F43-ARIES-DERF-Quark.jpg (259.72 KiB) Viewed 865 times
- Has thanked: 20834 times
- Been thanked: 10502 times
Re: AR12734 March 6 2019. SW 150mm scope + Quark.
These are nice images Valery!
- Been thanked: 4881 times
- Been thanked: 4981 times
Valery:
Very nice active zones.
- Been thanked: 8907 times
Lovely to see these tiny regions in such detail
Why did you stack all 4000 frames?
I've stacked different number of frames and this stack came out very good too. So, I processed it.
