AR12736, Lunt BF1200ST and a BF question
krakatoa1883
Has thanked: 39 times
Been thanked: 111 times
Post by krakatoa1883 » Mon Mar 25, 2019 9:58 am
Tried the new BF1200 on my Lunt-modified 104mm achromat by imaging the two active regions that have just disappeared beyond the limb. I preferred the straight-through version which I think is more versatile than the diagonal as it can be used in both modes. It comes with a 2" nose however a 1.25" nose is available separately and is the same as the 1.25" nose on the LS50 B600 diagonal.
I'm looking for a new BF for my Quark as I am not satisfied with the original one. Does anyone know if Coronado BF's can be used with Quarks ? (Lunt's are too dark).
Thanks!
MAURITS
Been thanked: 14 times
Re: AR12736, Lunt BF1200ST and a BF question
Post by MAURITS » Mon Mar 25, 2019 12:52 pm
Very nice results and great equipment Raf.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 54 times
Been thanked: 70 times
Post by MalVeauX » Mon Mar 25, 2019 1:41 pm
Lovely setup; would love to know more about how you modified the Lunt 50mm to work in your tube like that (such as what modifications, what ERF, etc).
As for your question, I think a coronado filter will work, but the Quark uses Andover HA filters as the blocking filter. You can buy them individually on their website, I think the 12mm version is what fits.
pedro
Has thanked: 2 times
Been thanked: 320 times
Post by pedro » Mon Mar 25, 2019 2:21 pm
I also would like to learn more on your LUNT50 mod. Please send us more details, thanks
krakatoa1883
Post by krakatoa1883 » Mon Mar 25, 2019 2:45 pm
Hi Marty and Pedro,
the mod is described here. It requires a Lunt LS50, FT focuser, some adapters and a front D-ERF, mine is a Baader 110mm masked to 104mm by its metal frame that fits on the cell. Oh, and a lot of backfocus for the reasons explained in the link.
I know the Quark BF is sell byAndover, however trying the device with a Lunt BF (instead of the original one) I noted a marked improvement in contrast and detail, so I am curious to try another BF to see the results.
Thanks Maurits :)
Best,
george9
Has thanked: 8 times
Been thanked: 6 times
Post by george9 » Mon Mar 25, 2019 3:23 pm
Excellent shots!
Very similar to my set up with an LS80 DSII unit on my 155mm refractor, then a second focuser. Then a Quark chromosphere. And a D-ERF in front.
Raf, I assume the LS50 PT unit has incoming and outgoing collimating lenses?
When you ask about the Quark blocking filter, the goal would be to remove the native Quark blocker and use that use this other blocker in its place? Specifically on this scope or in general for the Quark?
George
krakatoa1883
Post by krakatoa1883 » Mon Mar 25, 2019 3:48 pm
Thanks George. The Lunt should have collimating and refocusing lenses, I am using the PT module as it is, the optical train is as your one.
I removed the BF of my Quark (very simple, indeed) and using the device with the Lunt BF there is a marked improvement in contrast and details. Unfortunately Lunt BF's are quite dark but I read somewhere that Coronado BF are brighter, so I would be curious to try one.
PDB
Been thanked: 17 times
Post by PDB » Mon Mar 25, 2019 5:23 pm
Probably an older Quark? There is a security screw that does not allow the black body and telecentric to be removed. That screw should be unscrewed first, but it has that security torx(?) model. Tried a few but could not get anything to fit.
P
krakatoa1883
Post by krakatoa1883 » Mon Mar 25, 2019 7:33 pm
The BF can be removed from the bottom of the device by unscrewing the retaining ring, no need to open the Quark.
Has thanked: 1287 times
Been thanked: 534 times
Post by marktownley » Mon Mar 25, 2019 8:01 pm
That's a really nice result Raf! I guess you could try a coronado blocker, however it would need to be ahead of the quark to keep thermal load off the system.
PDB
Post by PDB » Mon Mar 25, 2019 8:26 pm
Noop, unfortunately not true anymore. That retaining ring is fixed with an ugly screw. You can unscrew the 2'" and 1.25" pieces, but not the the part that holds the telecentric and bf. (been discussed earlier on the forum, but couldnt find it.
P.
krakatoa1883
Post by krakatoa1883 » Mon Mar 25, 2019 8:42 pm
Thanks Mark, yes, my purpose is to insert the Quark in the diagonal BF.
Paul, this is the bottom of Quark and Quark Combo
to remove the BF I have simply to unscrew that little black metal ring that hold the BF in place. There are no screws and the BF is separated from the telecentric.
PDB
Post by PDB » Mon Mar 25, 2019 8:48 pm
Hi Raf,
Found it now, but there is fairly amount of glue used to seal the ring.
Was referring to this one if you want to take out the telecentric.
newer versions DayStar protected some removal.
That screw goes through the thread of the retaining ring (i suppose) impossible just unscrewing the black ring. :(
Rgrds
Post by marktownley » Mon Mar 25, 2019 8:55 pm
P.
How rude of them to make it tamper proof! :D
PDB
Post by PDB » Mon Mar 25, 2019 8:58 pm
Maybe a sledge-hammer will help ...
(but at least found how to get the bf out)
Has thanked: 440 times
Been thanked: 348 times
Post by Carbon60 » Mon Mar 25, 2019 9:31 pm
Nice images, Raf. Cool mod.
Stu
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Has thanked: 1119 times
Been thanked: 377 times
Post by Montana » Tue Mar 26, 2019 2:58 pm
Superb images Raf, very fluffy :bow :hamster:
krakatoa1883
Post by krakatoa1883 » Tue Mar 26, 2019 5:34 pm
Thanks Alexandra and Stu. I must admit that sometimes I get the impression that in our images the chromosphere looks a bit too much like a very large ball of wool, this is the reason why I prefer to image in CaH and in WL :lol:
