AR2738 in CaK
AR2738 in CaK
The idea for today was to image the sun in 5 wavelengths:
CaK
K-Line
Solar Continuum
White Light
H-alpha
But I only succeeded in taking one (1) AVI when the clouds rolled in.... So here is AR2738 in CaK.
100mm ED f/9 _ nosepiece of Lunt filter _ single K-line _ 2 PST#1 filters _ ASI290MM
Moon_111413_120419_Gain=64(off)_Exposure=5.9ms_Gamma=63apsize3232601_IMPPG_UM6 by bart moors, on Flickr
The picture is clearly undersampled, so I tried 1,5x Drizzle in AS!3.
Moon_111413_120419_Gain=64(off)_Exposure=5_randPS by bart moors, on Flickr
I kind of like the Drizzle version.
Thanks for watching!
Bart.
CaK
K-Line
Solar Continuum
White Light
H-alpha
Bart.
- Has thanked: 9144 times
- Been thanked: 6025 times
- Has thanked: 20435 times
- Been thanked: 10243 times
Re: AR2738 in CaK
They came out well Bart. What do you think an ideal focal ratio with this scope and camera setup would be?
Re: AR2738 in CaK
Thanks Franco and Mark!marktownley wrote: ↑Sat Apr 13, 2019 7:20 am They came out well Bart. What do you think an ideal focal ratio with this scope and camera setup would be?
Hard to say Mark, but I think somewhere between f/14 and f/16.
Re: AR2738 in CaK
Interesting Bart, I can image reasonably regularly this time of year with 100mm CaK at f15 ish, the 290 with its small pixels and fast frame rate offers a pleasing proposition... That is a focal ratio I could reach with the HaT and a 540nm filter too for some white light closeups... I'm selling it to myself here aren't I
- Been thanked: 4786 times
- Has thanked: 8415 times
- Been thanked: 8161 times
Re: AR2738 in CaK
Nice images, Bart. The drizzle version looks great.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Re: AR2738 in CaK
Beautiful images, Bart!
Raf
- Been thanked: 4340 times
Re: AR2738 in CaK
Lovely detail in the image Bart, and the drizzle version certainly looks the best to me.
Well done
Well done
- Has thanked: 1304 times
- Been thanked: 63 times
Re: AR2738 in CaK
Super image despite your session being cut short. Are you using the Skywatcher Evostar scope? If so how do you think it compares with other scopes you have used for Cak?
Re: AR2738 in CaK
Thanks guys!
No, it is an old Celestron 100mm F/9 ED. It is way better than the 150mm f/8 Skywatcher achromat.
- Been thanked: 2713 times
Re: AR2738 in CaK
Hello Bart,
I prefer the one without drizzle. Inverse granulation is lost in the drizzle version.
Re: AR2738 in CaK
You are right Christian, I did not notice it before you mentioned it. Should try and reprocess the drizzled version. Thanks! Bart.christian viladrich wrote: ↑Mon Apr 15, 2019 7:01 pm Hello Bart,
