Lunt 50mm question
- Has thanked: 9387 times
- Been thanked: 6201 times
Lunt 50mm question
Hello all: I recently received a Lunt 50mm Ha that I will use as a grab and go solar scope. It has the B600 blocking filter. Yesterday I was out trying to see if I can image with it and neither camera, PG Flea 3 2.5 microns or ZWO 174 5.86 microns, could reach focus. The focuser does not go in enough to reach focus: with the Flea 3 it almost does, but not quite.
The scope is 350mm focal length, F/7.
Any suggestions or experience from the group ?
Thank you,
Thank you,
- Lunt 50mm.jpg (1.13 MiB) Viewed 2019 times
- Has thanked: 65 times
- Been thanked: 4462 times
Re: Lunt 50mm question
Hi Franco...
Based on the pic there isn't a lot of easily removable pieces that would free up any in focus.
If you had a low power barlow (1.25x or so) it might push focus back enough to work out. Another thought is to get a lower profile 1.25" eyepiece hold so the camera sits lower, or try to shorten the scope side of the blocker...either should free up some travel. It is hard to tell in the pic, but there looks like a thick black fitting between the focuser and blocker body...can this be removed?
Jus a few thoughts,
Jus a few thoughts,
The nose of the diagonal need to be replaced with another one with shorter of it's wide part. You can win about 10-15mm.
Or use a Coronado BF10 instead.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Hello Franco, I had the same problem, the reason is the eyepiece holder which is too long. I solved with this adapter that threads between camera and diagonal
https://www.teleskop-express.de/shop/pr ... ength.html
Raf
Thank you Brian, Valery and Raf for your advice.
@Raf: so you remove the current eyepiece holder and replace it with the adapter from the link you sent ? How easy Is removing the eyepiece holder from the diagonal ?
Thank you,
Thank you,
- krakatoa1883
The eyepiece holder is simply screwed on the diagonal by a T2 thread. Use this thread to install the adapter (the other side attaches to the camera nose) and you should be able to image at prime focus. As the adapter doesn't allow to rotate and lock the camera, image orientation shall be changed by rotating the diagonal in the rear of the scope.
I would strongly suggest you to change the original focuser with a better one if you intend to use the scope for imaging. I installed a FT and works fine.
Raf
Thank you, Raf. Would you mind sending me a link for the FT focuser you installed ?
Thank you,
Thank you,
- Has thanked: 20962 times
- Been thanked: 10593 times
Replacing the EP holder on the diagonal with one of these https://www.365astronomy.com/Visual-Bac ... rsion.html and using a short c mount nosepeice on the camera will get you in to focus.
Maybe this is interesting Franco:
https://www.cloudynights.com/classified ... t-ls50tha/' title='Feather Touch Focuser for Lunt LS50THa
- pedro
- Has thanked: 14 times
- Been thanked: 6754 times
I had the same problem when I used a LUNT50 belonging to a friend. You have to use a low profile 1 1/4" adapter (see the second and third photo) to reach focus. Changing the focuser for a FT also helps
IMAGING SETUPS (LUNT50)
- lunt50_20180616-07.jpg (917.09 KiB) Viewed 1944 times
- lunt50_20180616-06.jpg (894.17 KiB) Viewed 1944 times
- lunt50_20171202-07.jpg (682.9 KiB) Viewed 1944 times
- lunt50_20171202-01.jpg (1.16 MiB) Viewed 1944 times
Pedro Re'
You are using a 2" diagonal that is why
72mm Ed Skywatcher for Solar
SkyTee 2
Sky-Watcher SolarQuest
Gitzo Systematic Series 5
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
It has the standard Lunt blocking filter body...just needs to have the camera moved closer to the diagonal body or a shorter spaced connecting the focused/blocker body.
- pedro
https://www.teleskop-express.de/shop/pr ... short.html
Visual Back T2 to 1.25" - with additional T2 male thread - short
- tst2-1-t2s_500.jpg (46.85 KiB) Viewed 1923 times
Pedro Re'
Thank you all for your help ! I am glad I consulted the group on this...
- krakatoa1883
It is this one
https://www.teleskop-express.de/shop/pr ... ength.html Replacing the original holder with a shorter one as suggested by Mark might not work if the nose of your CCD camera is too long because it would end against the blocking filter cell.
Raf
I managed to get a 10mm length c-mount to 1.25" nosepiece from ebay, it was good quality and with the other adapter allowed me to get in close. I want to try my Lunt 50 up and running again soon, maybe over the next couple of days. The double stack of external etalons i've used on the travelling setup is too fiddly to quickly get it up and running for imaging. Visually it is great but I want to try the 50 again, if I can get the sloppy etalon on it square again and not slopping around would be good. I went for the moonlite focuser on my 50. I tried the feathertouch but in this instance the Moonlite is superior IMHO, I sold the feathertouch in the end.
Hi all...
I sent this option to Franco earlier this afternoon, but if the helical focuser has t-thread you could remove the nosepiece of the blocker and fit them with a threaded adapter with internal female threads. I have a commercial adapter and the internal threaded ring from a T-ring shown in the pic. I put this together years ago when I received my first Lunt filters for a scope that the supplied adapters would not work.
If there is no thread on the focuser you can ignore this , just couldn't tell int he pic or on the sample pics on the Lunt website.
Here's a picture of the back end of my Lunt 50 setup. I use the moonlite focoser, Coronado bf15 and then the tube off a 2x skywatcher Barlow (minus the lens) and then the eyepiece.
- GreatAttractor
- Has thanked: 750 times
- Been thanked: 758 times
I have a Borg helical focuser and a custom T2/C-mount low-profile adapter, see the second picture in this thread: viewtopic.php?t=18394
