Saturday Sun 11th May '19 Sunday Sun images added
Has thanked: 8523 times
Been thanked: 8252 times
Post by Carbon60 »
The day turned out better than expected, with a beautiful blue sky morning and some afternoon Sun with a short spell of threatening clouds between. The seeing during the morning session was sublime, registering as low as 0.5 arc seconds for brief periods on the SSM. The average was around 1, steadily getting a little worse as the morning progressed.
Active Regions 2740 and 2741 looked superb on screen through my 150mm/DS Lunt35/Basler acA1920-155um combo and 2.5x Powermate.
I tried to do them justice with a multi-pane mosaic:
Image20190511_Ha_AR2740_AR2741 by Stuart Green, on Flickr
And then a couple of individual shots:
AR2740
Image20190511_Ha_AR2740 by Stuart Green, on Flickr
AR2741
Image20190511_Ha_AR2741 by Stuart Green, on Flickr
The two regions also looked great in CaK II, with really bright plage.
Captured with my Tecnosky 125mm, same camera, with a 2.7 Barlow, Lunt B600 module, Baader K-line and Omega filter.
Image20190511_CaK_AR2740_AR2741_125_2 by Stuart Green, on Flickr
Image20190511_CaK_AR2740_AR2741_Colour_125_2 by Stuart Green, on Flickr
I even tried a WL image for a change, using a Lacerta solar wedge (Brewster angle type):
Image20190511_WL_AR2740_AR2741_Colour_125 by Stuart Green, on Flickr
A break for some chores when the clouds arrived and then back to it in the afternoon for Ha and CaK FDs.
Image20190511_Ha_FD_60 by Stuart Green, on Flickr
Image20190511_Ha_FD_Colour_60 by Stuart Green, on Flickr
Image20190511_CaK_FD_72 by Stuart Green, on Flickr
Image20190511_CaK_FD_Colour_72 by Stuart Green, on Flickr
Apologies for not getting the images in the correct orientation.... :oops:
Thanks for looking.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Re: Saturday Sun 11th May '19
Post by MAURITS »
A lot of very fine images Stu.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Astrophil
Been thanked: 581 times
Post by Astrophil »
Stu, those are Great! All of them, and a little something for everyone. Job well done.
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
A fantastic set, Stu. Looks like you had one of those rare days with excellent conditions. The results speak for themselves.
Been thanked: 4957 times
Post by eroel »
Stu:
Super images.
mattwastell
Has thanked: 2 times
Been thanked: 72 times
Post by mattwastell »
Excellent session Stu - the AR's look great in all lights - thanks for the views!
Matt Wastell
Look up, look good!
http://www.pbase.com/mattwastell
Re: Saturday Sun 11th May '19 Sunday Sun images added
Post by Carbon60 »
Many thanks, guys. Much appreciated.
Post by Carbon60 »
Just a few from this morning (Sunday 12th).
AR2741 in Ha (150mm/DS Lunt 35)
Image20190512_AR2741_Ha_150 by Stuart Green, on Flickr
AR2740- The dark core has completely disappeared.
Image20190512_AR2740_Ha_150 by Stuart Green, on Flickr
And back to AR2741, this time in CaK on the Tecnosky 125mm.
Image20190512_AR2741_CaK by Stuart Green, on Flickr
Image20190512_AR2741_CaK_Colour by Stuart Green, on Flickr
I think that's the last I'll see of these guys.
Thanks for looking.
Davidm
Has thanked: 1 time
Been thanked: 289 times
Post by Davidm »
Fantastic images, Stu. Great detail in the CaK.
Lunt LS152T (DSII and CaK module), Coronado Helios 1, Grasshopper 3 2/3" CCD
David_The_Bears_Fan
Has thanked: 423 times
Been thanked: 167 times
Post by David_The_Bears_Fan »
A great haul of images there Stu. Made the most of the decent weather.
David
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
An awesome set, Stu.
It's pretty exciting when the seeing cooperates!
Peter
Christopher
Has thanked: 33 times
Been thanked: 34 times
Post by Christopher »
Awesome set Stu!
Christopher
Has thanked: 64 times
Been thanked: 4406 times
Post by MapleRidge »
A superb set of images Stu...excellent work :bow
Been thanked: 10430 times
A really productive session there Stu and excellent images to!
Astrophil
Post by Astrophil »
Great additions, Stu. Looking closely into the sunspot of the first Ha image from today (12th), what is that squiggly feature crossing it? It was gone by the time I looked. Very interesting to see.
Post by Carbon60 »
Many thanks, everyone. The Sun certainly put on a good show over the weekend AND the weather cooperated.....
An interesting transient feature across the umbra, as you say, Phil.
Has thanked: 17894 times
Been thanked: 8887 times
WOW!! these I think are some of your best ever! if only I could get CaK like you :) you should have used the monster scope :)
:bow
Post by Carbon60 »
Montana wrote: Mon May 13, 2019 11:40 am WOW!! these I think are some of your best ever! if only I could get CaK like you :) you should have used the monster scope :)
:bow
Thanks, Alexandra. I agree with you. I worked hard to tease out as much data as I could from my SER files and to collect good data in the first place. I think everything came together just right, for a change.
I did try with the big gun on Saturday, but everything was absolutely rubbish. I spent over an hour on the following day checking and adjusting the collimation, but the views were still as bad.... I’ll check and adjust again..... not sure what else to do.
Stuart, I think there probably is. On Sunday I took several SER files which, when I watch them they are beautiful. I see lots of detail and if I extract single frames they a lovely. However, the stacks are just blurs. Therefore if I can get multiple single frames out which are publishable and the video is great to watch, then something is going wrong in the stacking. This has always been my first port of call, watch the video, does the video represent what you see in the final image? in this case, most certainly not. So I need to understand the stacking program more. Have you looked at your videos with the big scope? can you process a good single frame? how do they compare. I think we are missing something here with the large aperture processing. If I could have logged on to Flickr last night I could have shown you what I mean ;)
Post by Carbon60 »
Interesting, Alexandra. Maybe Valery knows a trick or two :)
