June 1st images
June 1st images
I hadn't planned to image today but a quick glance at GONG showed a nice looking surge prom developing so out I went. This was about 14:50 UT. By the time everything was setup and the etalon was up to temperature the show was over. I missed it. Maybe next time.
I did capture a region of disturbance and a prom for my efforts.
- Has thanked: 8418 times
- Been thanked: 8161 times
Re: June 1st images
That’s the way it goes sometimes, Phil. Usually it’s weather related.....just get set up and the clouds roll in to spoil the show.
Great images. Lots of lovely fine structures in that prom shot.
- Been thanked: 4904 times
- robert
- Has thanked: 4 times
- Been thanked: 1274 times
Re: June 1st images
Very fine prom detail, great
Robert
Robert
- Has thanked: 2412 times
- Been thanked: 4786 times
- Has thanked: 9144 times
- Been thanked: 6025 times
- Been thanked: 4340 times
Re: June 1st images
Nicely detailed image Phil
Re: June 1st images
As always, thanks for the kind remarks. Definitely helps during the slow Solar season.
Re: June 1st images
Excellent resolution at the edge. Fantastic spiculaes.
I see your etalon was somewhat off-band. Spiculaes better seen when an etalon is somewhat red shifted.
BTW. The seeing often is good just before clounds are rolled on.
Re: June 1st images
Valery, you are absolutely correct. I did set the etalon temperature approximately 1.5°C hotter (red) that normal.
- Has thanked: 1171 times
- Been thanked: 1360 times
- Has thanked: 20435 times
- Been thanked: 10245 times
Re: June 1st images
These are nice images Phil!
- Has thanked: 17667 times
- Been thanked: 8789 times
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Re: June 1st images
Hi Alfred,
Here is a pic of the setup. These images were taken without the Daystar Combo. It was replaced with an extension tube.
viewtopic.php?f=4&t=25497
- yltansg
