Sol from the 9th of June 2019.
Post by eroel » Mon Jun 10, 2019 3:01 am
Hi:
Well, we are in the rainy season but today I found some holes through clouds but not through the upper haze and got some images with the Solarmax 90-DS, with the 102Meade with the CaK mod and with the 102mm Stellarvue working at f/28 with an old Daystar T-Scanner filter,
Used the SKYnyx 2-2 and also tried the ASI290 for some shots.
The last 5 look better in another window.
Thanks for looking.
Sol del 9 de junio del 2019-Meade-CaK-PSTmod-2an.jpg (806.39 KiB) Viewed 155 times
Sol del 9 de junio del 2019-Meade-CaK-PSTmod-2inv.jpg (892.7 KiB) Viewed 155 times
Sol del 9 de junio del 2019-Meade-CaK-PSTmod-2inv-neg.jpg (897.82 KiB) Viewed 155 times
Sol del 9 de junio del 2019-Meade-CaK-PSTmod-2neg.jpg (841.84 KiB) Viewed 155 times
Sol del 9 de junio del 2019-Solarmax 90-DS-BF30-1an.jpg (947.08 KiB) Viewed 155 times
Sol del 9 de junio del 2019-Solarmax 90-DS-BF30-1inv.jpg (1011.13 KiB) Viewed 155 times
Sol del 9 de junio del 2019-Solarmax 90-DS-BF30-1inv-neg.jpg (1.1 MiB) Viewed 155 times
Sol del 9 de junio del 2019-Solarmax 90-DS-BF30-1neg.jpg (957.37 KiB) Viewed 155 times
Sol del 9 de junio del 2019-Stellarvue-Daystar-2an.jpg (1.11 MiB) Viewed 155 times
Sol del 9 de junio del 2019-Stellarvue-Daystar-2inv.jpg (1.22 MiB) Viewed 155 times
Sol del 9 de junio del 2019-Stellarvue-Daystar-2neg.jpg (1.07 MiB) Viewed 155 times
Sol del 9 de junio del 2019-Solarmax 90-DS-ASI290-1an.jpg (1.71 MiB) Viewed 155 times
Sol del 9 de junio del 2019-Solarmax 90-DS-ASI290-2inv.jpg (1.86 MiB) Viewed 155 times
Re: Sol from the 9th of June 2019.
Post by marktownley » Mon Jun 10, 2019 5:40 am
These look good Eric! What are your impressions of the 290M compared to your other cameras?
Post by Montana » Mon Jun 10, 2019 9:15 am
These are beautiful Eric, especially the proms :bow
MAURITS
Post by MAURITS » Mon Jun 10, 2019 10:58 am
Real nice images Eric.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Post by ffellah » Mon Jun 10, 2019 11:04 am
A beautiful series, Eric. The large prominence shows a lot of fine detail.
Post by eroel » Mon Jun 10, 2019 2:58 pm
Alexandra, Mark, Maurits and Franco:
Thanks for looking and commenting the shots.
Mark, this is my first try with the 290M and I liked it.
It is funny, Chris Go recommended it to me at NEAF, as also the 174M years ago when it came out, but had seldom used the 174M because had to learn other softwares to get it going.
I am used to the Lucam Recorder program since Heiko started it, so I just have cameras that work with it like the TIS, Lumeneras, etc., exception made of some other brands like ZWO, QSH, Skyris, etc, that I try to control with other softwares like FireCapture, Genika and others new and old.
For the 2 shots with the 290M I used FireCapture, but I still have to get used to the many tools it has, as also how to set correctly the Gamma, Gain, etc, etc, parameters, but I can say that the camera was working at 84 fps with no trouble, so it helps a lot as you can see with the detail in the prominences.
Best regards to all,
xn44
Post by xn44 » Mon Jun 10, 2019 6:11 pm
Super captures Eric!
Users browsing this forum: No registered users and 7 guests
