Transit of Mercury in the Spicule Layer. Phil took this great image with his Quantum 6 Scope, Solar Spectrum etalon and PGR Camera.
Anybody want to share their unprocessed source AVIs
GreatAttractor
Re: Anybody want to share their unprocessed source AVIs
Post by GreatAttractor » Sun Jun 23, 2019 7:28 am
Starry Jack wrote:
Sat Jun 22, 2019 1:54 pm
Because I am greedy (not really) if you have a post processed version of those files and steps well take those as well,
Done - uploaded raw stacks, processed images and ImPPG settings files for each.
My approach:
My software:
My images
Starry Jack
Post by Starry Jack » Sun Jun 23, 2019 12:42 pm
My bad! I've removed the fat file. Just left the skinny one. 👍
Aeries D-ERF
ZWO174 (IMX249 chip 5um)
Starry Jack
Post by Starry Jack » Sun Jun 23, 2019 1:47 pm
Mark,
Sorry for the big file. I have removed it. Great suggestion.
Aeries D-ERF
Starry Jack
Post by Starry Jack » Sun Jun 23, 2019 1:49 pm
Filip,
You are so generous! Thank you for the new files and settings. My skills and confidence are increasing because of the exercises and I hope others will enjoy as well.
Jack
Aeries D-ERF
Starry Jack
Post by Starry Jack » Mon Jun 24, 2019 4:38 pm
Alexandra,
Again thank you for the files. I'm experimenting with those Inverse curves which give that 3D look. Here is yours, a bit over processed, but gotta keep learning.
I'll work on Filip's more as well. :)
Alexandra Hart - Processed by Jack Swaton as a TEST 021016_092304 AS3 to IMPPG with Inv 1 v1.png
Alexandra Hart - Processed by Jack Swaton as a TEST 021016_092304 AS3 to IMPPG with Inv 1 v1.png (2.96 MiB) Viewed 325 times
Aeries D-ERF
Starry Jack
Post by Starry Jack » Mon Jun 24, 2019 4:54 pm
And a quickie with Filip's. Trying to tame the ImPPG Curves is fun...advice welcomed.
Filip Szczerek - example3_stack Processed by Jack Swaton as a TEST v14.png (1010.66 KiB) Viewed 325 times
Aeries D-ERF
Post by marktownley » Mon Jun 24, 2019 5:47 pm
Can I make a suggestion Jack, check the 'cropped' box in AS3, it will get away with those image edge artefacts.
Starry Jack
Post by Starry Jack » Mon Jun 24, 2019 6:22 pm
Thank you, Mark. I will take every suggestion.
Aeries D-ERF
