This prom is the a development of the prom that was in the same position on the sun as last day except that it has "bloomed" outwards. Its appearance was very feint on GONG and appeared even more so in the the live view because of the haze.
So, there was some levels work involved to make it more contrasty and stand out.
An LS152 + standard Quark Chromosphere + Blackfly S(3.2 Mp at 1536x1536 ROI) were used, unfortunately with a fairly slow shutter speed and high gain.
Lou
I used more aggressive processing in the next image to bring out a bit more detail in some areas.
Big Prom on July 21
- Been thanked: 1735 times
- Has thanked: 9149 times
- Been thanked: 6030 times
- Has thanked: 20448 times
- Been thanked: 10254 times
Re: Big Prom on July 21
That looks excellent Lou!
- Been thanked: 8795 times
Thanks for the comments and views.
I can't wait for more of these great proms.
Lou
Lou
- Been thanked: 4788 times
- Been thanked: 4343 times
Outstanding images Lou...the resolution is very sharp.
- pedro
- Has thanked: 14 times
- Been thanked: 6582 times
