Prom group Sept. 7th Quark/Questar
I hadn't warmed up the Quark since May. Saturday the Quark Combo and the little Questar 3.5 were used to image the nice group of proms. Not many Ha images taken with a Questar are seen here so I thought this might be of some interest. An adequate image none the less.
Questar, 2.5x Powermate, Quark Combo, PGR GX-FW-28S5M camera
Phil
Phil
- Has thanked: 20757 times
- Been thanked: 10444 times
Re: Prom group Sept. 7th Quark/Questar
That is an excellent image there Phil! Assuming you used a DERF up front?
- Has thanked: 9298 times
- Been thanked: 6133 times
Thanks Franco and Mark. Yes, I use a Baader DERF up front and a circular polarizer on the Quark to cut some internal reflections. This Quark can produce a bright glow next to the limb on one side of the Sun and requires the Quark to be rotated in order to minimize the problem when imaging proms. Full disks are more difficult with this setup. Luck of the draw I guess.
Phil
Phil
- Has thanked: 2463 times
- Been thanked: 4879 times
- Has thanked: 141 times
- Been thanked: 240 times
Interesting use of the polarizer. Great image.
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- pedro
- Has thanked: 14 times
- Been thanked: 6686 times
Excellent Image Phil.
Pedro Re'
- Been thanked: 4959 times
- Has thanked: 1182 times
- Been thanked: 1373 times
- Has thanked: 17813 times
- Been thanked: 16953 times
WoW, the little Questar does really well with the Quark! Awesome!!
- Has thanked: 8523 times
- Been thanked: 8259 times
Very nice prom images, Phil.
- Been thanked: 4407 times
Really love the details in this image Phil
Great capture and processing,
Thanks James, Stu, and Brian for the kind words. Sometimes the little Questar does good, contrary to what many folks say. It's a good choice when the disk is so blank and a lot easier than lugging out the bigger scope.
Phil
Phil
- Has thanked: 17925 times
- Been thanked: 8895 times
Superb detail in the proms and lovely processing too
