Some Images in Ha with Quark Chrosphere Oct. 12, 2019
hopskipson
Has thanked: 3 times
Been thanked: 2 times
Post by hopskipson » Sun Oct 13, 2019 7:59 pm
I had a chance to do some imaging from my balcony, between the clouds on Saturday. Equipment used ES 102 ED with Quark chromosphere and ASI 174MM. Seeing was not great around 3 arcseconds. Thanks for looking! My processing skills are very rough. Any suggestions, comments, tutorials welcomed!
Has thanked: 5 times
Been thanked: 110 times
Re: Some Images in Ha with Quark Chrosphere Oct. 12, 2019
Post by MapleRidge » Sun Oct 13, 2019 9:33 pm
Your images turned out quite well, showing some nice detail in the brighter proms...well done :bow
Starry Jack
Has thanked: 17 times
Been thanked: 47 times
Post by Starry Jack » Sun Oct 13, 2019 9:38 pm
I like them all. What is your processing workflow? Do you use IMPPG? That is key for me to really adjust some curves, contrast and LR Deconvolution.
Aeries D-ERF
ZWO174 (IMX249 chip 5um)
hopskipson
Post by hopskipson » Sun Oct 13, 2019 11:23 pm
Thanks for the comments all help is appreciated!
I start by stacking in AS3! The above were 50 frames out of 500. Then start processing in ImPPG. I try not to go to hard on the sigma for LR and the unsharp mask. If I capture the surface and prom area, I invert the surface and bring out the proms. Then I finish it off in Gimp with a slight unsharp mask and some curves adjustment. I'll invert the surface/prom image. I think the Gimp part is where I could improve. I just don't know how to manipulate the image and what each function does or how to process one area without overdoing another area. I've tried to search for tutorials but they don't apply to solar images.
Starry Jack
Post by Starry Jack » Mon Oct 14, 2019 4:19 am
What is your Quark dial set at? Idike to s3e more contrast on the surface portions and that is where my questions are driving.
Also, which capture software are you using and are you using any kind of secondary filter like a polarizer or a UVIR Cut?
Cheers,
Jack
Aeries D-ERF
MAURITS
Been thanked: 14 times
Post by MAURITS » Mon Oct 14, 2019 5:59 am
Well done.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
hopskipson
Post by hopskipson » Mon Oct 14, 2019 11:22 am
Cheers,
Jack
I have my Quark set to a far counterclockwise as it can go. This seems to bring out the most contrast. I seem to loose the contrast when I try to bring out the proms in ImPPG. If you notice it's not such a problem when I just focus on the surface at least to me. I'm using firecapture and try to fill the histogram to about 70%. I use an UVIR cut and a Ha CCD filter before the Quark. I don't have a polarizer. Will that make a big difference? Thanks for the comments!
hopskipson
Post by hopskipson » Mon Oct 14, 2019 11:24 am
This is what I mean without proms. It shows a bit more contrast.
Has thanked: 1112 times
Been thanked: 376 times
Post by Montana » Mon Oct 14, 2019 11:53 am
This is a super set well done :bow :bow :hamster:
There are lots of tutorials in the Solar reference library, my particular favourites are from Mark T's website links in the ref library. However I think most are using Photoshop but when I have used GIMP I have found most methods can usually be found in there when you look hard enough. The principles seem to be similar across both programs.
Has thanked: 1265 times
Been thanked: 524 times
Post by marktownley » Mon Oct 14, 2019 7:04 pm
Nice shots! My advice to improve - just use LR not USM, certainly not both together. The 'dotty' noise in the images says to me you are using too many iterations. Using a flat will help things too.
hopskipson
Post by hopskipson » Mon Oct 14, 2019 10:55 pm
Thanks for all the advice and positive comments! Thanks Alexandra for the extremely kind words. I'm my worst critic. I reprocessed the following without USM only LR. Are they an improvement? Thanks.
Has thanked: 498 times
Been thanked: 538 times
Post by DeepSolar64 » Mon Oct 14, 2019 11:50 pm
Very nice! I viewed these proms visually using my SM60 DS.
Has thanked: 225 times
Been thanked: 120 times
Post by ffellah » Tue Oct 15, 2019 12:31 am
Very nice chromosphere close-ups !
