C11 ARIES ERF + Lunt Calcium K-Line B1200 Wedge
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
It was another cloudy morning followed by rain. The Sun's lower chromosphere didn' have any filaments. I am very glad to make some videos. The setup:
ARIES D-ERF + C11 + Lunt Calcium K-Line B1200 wedge + x2 barlow + Basler Ace Asa1920 -155um mono camera.
An useful image from the 30 minute session. Because of the poor seeing I had to pump up the gain to the maximum and increased the exposure 7000µS. As a result I wasn't able to freeze the seeing. Hence I was quite happy to get this image.
Please do a right click to see the image in full resolution.
Alfred
Alfred
- Been thanked: 4881 times
- Been thanked: 4434 times
Re: C11 ARIES ERF + Lunt Calcium K-Line B1200 Wedge
Excellent shot Alfred considering the exposure and other limits you had to deal with. Well done
- Been thanked: 8907 times
Wow! that is a stunning image! was that at full aperture? if so then
- yltansg
Thanks Maurits and Brian. Even though the images are not great, these sessions in the inter-monsoon period provide good practice for me to get ready for an active Sun later.
Alfred
Alfred
- yltansg
Dear Alexandra,
It was imaged at full aperture. I am very impressed by the D-ERF + Lunt CAK wedge combination. It is able to produce a reasonable image in cloudy situation.
Alfred
Do you suffer from the Jetstream?
I am starting to think it might be the problem that we suffer from and you and Val do not
- Has thanked: 20828 times
- Been thanked: 10502 times
Came out well Alfred!
- Has thanked: 8559 times
- Been thanked: 8297 times
Nice close view image, Alfred.
- yltansg
Dear Alexandra,
Jetstream is something we don't talk very much about in this region. May be we are just ignorant of it or its impact not that great on us. This article tells us vaguely that we are not spared.
https://www.straitstimes.com/world/blowing-hot-and-cold
Some of my videos show very poor and unsteady images, with running focus. However I am still able to get fair images with lucky imaging during stacking with AS!3.
Alfred
Alfred,
If you still don't own a SSM, you need to buy it and install a plugin to use it with the FireCaptue.
Possibly, you need more transparent CaK filter (they are different) or even to use Quark CaK which, I have heard, are more
transparent than CaK by Lunt. Aso, a camera must be maximally sensitive at this wave length, lowest noise and maximally speedy.
May be ASI290MM is a right choice, but I am not sure. Pint Gray Research cameras are known to have independent high quality
power source and this makes their cameras much less noisy.
Summarize: for good results in CaK one need all components best of the best.
The ASI178MM is more sensitive in the blue than the 290MM, so that could be a good choice for CaK imaging.
- yltansg
