Interference eliminator and tilt adjuster
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Newton rings and banding can be eliminated or reduced using a tilt adjuster. Check out a few examples below:
Daystar interference eliminator
TS tilt adjuster...
TS tilt adjuster...
- tilt_adjuster_20180706.jpg (51.04 KiB) Viewed 3665 times
- solar_imaging_session_20190831-040.jpg (918.54 KiB) Viewed 3665 times
- daystar_interference_eliminator_QUARK_20191025-01.jpg (1.7 MiB) Viewed 3665 times
- daystar_interference_eliminator_QUARK_20191025_mosaic.jpg (1.17 MiB) Viewed 3665 times
- daystar_interference_eliminator_20191025-11.jpg (965.38 KiB) Viewed 3665 times
- daystar_interference_eliminator_20191025-10.jpg (962.58 KiB) Viewed 3665 times
- daystar_interference_eliminator_20191025-06.jpg (1005.42 KiB) Viewed 3665 times
- daystar_interference_eliminator_20191025-04.jpg (1.43 MiB) Viewed 3665 times
- daystar_interference_eliminator_20191025-03.jpg (1.38 MiB) Viewed 3665 times
Pedro Re'
- Has thanked: 20435 times
- Been thanked: 10245 times
Re: Interference eliminator and tilt adjuster
The daystar interference eliminator is my personal favourite Pedro. I use mine on the ep end to connect it and the camera to the quark.
- pedro
Thanks Mark
I use mine before the camera. I used the Daystar today for the first time and it's great, not cheap though
Pedro Re'
- Been thanked: 4786 times
Very nice detail pictures Pedro.
I like my Daystar Eliminator a lot.
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
The cheapest tilt plates with thumbscrews are awful IMO.
The push & pull thumbscrews are far too close together to allow easy adjustment.
I intended to fit mine with hex socket head screws so I can adjust the tilt with a long series hex key or hex driver.
- P1390421 rsz 700.JPG (63.84 KiB) Viewed 3617 times
- Has thanked: 173 times
- Been thanked: 615 times
I use the ZWO T2 tilter on both my ASI 174 and ASI 1600 cameras.
I agree the screws can be fiddly but once done never need to move.
Ken
Ken
- Has thanked: 8415 times
- Been thanked: 8161 times
The Daystar product looks nicely engineered. I guess you get what you pay for.
- pedro
I have both, cheapest tilt plates and daystar interference eliminator. The best is the daystar acc but it is also expensive
Pedro Re'
- Has thanked: 17667 times
- Been thanked: 8789 times
I have the ZWO tilt adaptor and my brain physically cannot work out how to move it in any way. It always move the opposite way to what I want or is too tight to move, then you loosen it and you are back to square one. I have no idea in the slightest how to use it, I just don't understand the mechanism.
- Rusted
Play with the tilt plates while free of the telescope and camera to familiarize yourself with its movements and to gain confidence.Montana wrote: ↑Sun Oct 27, 2019 9:56 am I have the ZWO tilt adaptor and my brain physically cannot work out how to move it in any way. It always move the opposite way to what I want or is too tight to move, then you loosen it and you are back to square one. I have no idea in the slightest how to use it, I just don't understand the mechanism.
The system is a push-pull mechanism. Meaning that three screws push the plates apart and three screws pull the plates back together.
Both types of screw are arranged side by side. The large screw heads pull in. The smaller ones push the plates apart.
You can only push in one place if you loosen all the pull screws.
The pairs of screws are arranged 120° apart.
To separate one area of the plate you must loosen all the pull screws and then screw only one push screw in.
The confusion lies in that all three pull screws need to be loosened to get the plates to separate at all.
If you don't loosen them all the plates remain tightly fixed together.
So loosen all the pull screws first. But not too much so it all falls apart in your hands.
Now tighten only one push screw. This will separate the plates in one place. This is a good starting point.
Now re-tighten the other pull screws gently. So that the plates still have an open "wedge" between them.
The other push screws can now be gently tightened to take up the slack. This is the basic arrangement.
Once satisfied all the screws can be tightened finger tight.
The main problem is finding the ideal tilt angle between the plates.
And, the best orientation of the plates around the camera axis.
- Rusted
Apologies if your ZWO tilt plate adapter has socket head screws [like Pedro's top image]
Rather than the big thumbscrews shown in my image above.
I ordered ZWO but may have received a clone.
If this is the case then the system is identical but the screws just look different to mine.
Sell it and get the Daystar one, so much easier to use.Montana wrote: ↑Sun Oct 27, 2019 9:56 am I have the ZWO tilt adaptor and my brain physically cannot work out how to move it in any way. It always move the opposite way to what I want or is too tight to move, then you loosen it and you are back to square one. I have no idea in the slightest how to use it, I just don't understand the mechanism.
Pedro shows the TS tilter, which looks different to the ZWO version (which has the thumb screws).
- pedro
solar_imaging_session_20191026-06 by Pedro Ré, on Flickr
Daystar interference eliminator + QUARK Chromosphere + ASI174MM
solar_imaging_session_20191026-041 by Pedro Ré, on Flickr
Pedro Re'
- Has thanked: 141 times
- Been thanked: 240 times
Egad. Now I worry I did not do it right! I have the $30 ZWO with thumb screws and got it working in about three minutes. Never touched it since and never have rings.
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
Jack,
Sounds OK to me.....
It depends from setup to setup.Starry Jack wrote: ↑Fri Nov 01, 2019 1:33 am Egad. Now I worry I did not do it right! I have the $30 ZWO with thumb screws and got it working in about three minutes. Never touched it since and never have rings.
I tried this too but it failed to remove the NR, when you have too much tilt, than you create other problems.
The only solution was the Daystar Interference Eliminator, with a min. tilt NR problem solved.
Maurits,
Tilt is tilt no matter what the mechanism....
I agree, but the Daystar Interference Eliminator tilts the camera off-normal by up to 5° while keeping the center of the image sensor stationary, so that focus, framing, and vignetting are not affected.
This was my extra problem (vignetting) with my ZWO tilter.
- pedro
IMHO the Daystar Interference Eliminator is the best choice
Pedro Re'
I do believe I have some vignette for sure. I just did not have the funds.
BTW my unit is between the camera and quark not quark and telescope.
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
- pedro
I also use the daystar interference eliminator between the camera and the quark
Pedro Re'
Hmmm
I'm not sure I have ever used tilts up to 5 deg....At the 70mm centres of the ZWO tilter this would mean an "opening" of just over 6mm!!!
I'm working with the ASI 1600, x2.5 PM with an "opening" tilt of 2.3mm. I don't seem to be experiencing any vignetting with this set-up.
Don't forget there are 2 Daystar interference eliminators, c-mount and t-mount. I have a the c-mount and if I use it with a c to 1.25" nosepiece I have that has not got full clear aperture then I get vignetting, using a c to 1.25" that is full clear aperture its fine.
- The Sun?
- Been thanked: 3 times
It seems like if you started with a system that had uniform flat focus and Newton rings, then put a tilt on it to eliminate the rings, the focus would no longer be uniform. For night-time astronomy, tilters are used to fix out of focus and elongated starts from sensor tilt. My understanding is that's more pronounced with faster scopes and we are using super-slow scopes, but still, 5 degrees might be fine for newton rings but seems like a lot for the focal plane.
I have no hands-on experience with any any titter, so please excuse my ignorance if the answer is obvious once you use the equipment, I'm just trying to do research in advance.
- pedro
These tilters are mainly used reduce newton rings in CMOS cameras. The Daystar interference eliminator is the best I've use so far
Pedro Re'
