New Plage, Proms & Cells | Oct 29th 2019
Has thanked: 1182 times
Been thanked: 1373 times
Post by MalVeauX »
Woke up to an ok sky, clouds, but had a chance. Got some data later in the afternoon, so seeing was poor, but managed. The new plage is interesting and there are some proms in the quadrants on the limbs. Took at look at the plage in two scales and both from the chromosphere & photosphere perspective.
Colored:
B&W:
Equipment:
C8 Edge + Aires D-ERF + Baader Red CCD-IR Block Filter
120mm F10 Frac
PST Module
ASI290MM
Has thanked: 8523 times
Been thanked: 8259 times
Re: New Plage, Proms & Cells | Oct 29th 2019
A great set of images, Marty. Nice to see a little activity stirring up, there. Looks good in WL too.
banjo
Has thanked: 2098 times
Been thanked: 2874 times
Post by banjo »
Superb Marty. :bow :bow :bow :bow
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
Excellent images Marty.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 20757 times
Been thanked: 10442 times
These are excellent images Marty!
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Nicely done, Marty. Excellent close up of the active region.
Has thanked: 17925 times
Been thanked: 8894 times
Super images but in the WL I don't think I can see any pores so that is a bit disappointing but then again I don't think we can hope for much these days out of cycle 24 :) Still a beautiful swirl in Halpha though :hamster:
:bow :bow
MAURITS
Post by MAURITS »
Marty, is the first image in WL done with a wedge or with film filter?
Maurits
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Excellent images Marty :bow
That bit of activity looked promising, but has never grown into anything that NOAA assigned a number to!
Post by MalVeauX »
Thanks all :bow
MAURITS wrote: Wed Oct 30, 2019 9:16 pm Marty, is the first image in WL done with a wedge or with film filter?
I don't use film nor wedges for imaging, they lower transmission too much.
That first image was done with my C8 Edge and my full aperture Aires D-ERF followed by a Baader Red CCD-IR blocked filter (2nd erf). The transmission is so high that I have to then use a Baader 10 stop ND filter. I sometimes then use a Baader 610nm filter after that, but it's not needed. Transmission is still so high that this only gives me a little room to work with since the shortest exposure is 0.032ms and this one was at 0.281ms with no gain.
When I do it with my refractor, I only use a Baader Red CCD-IR block filter as the primary ERF deep in the light cone, or the Blue version of the same filter if I'm doing 393nm or 430nm. And then follow it with a narrowband filter with an appropriate UV/IR block filter to complete the blocking but maintain high transmission. And I often have to use a 10 stop ND filter here too to lower transmission enough to not saturate at the shortest exposure.
MAURITS
Post by MAURITS »
Thanks Marty for the clear explanation.
Maurits
pedro
Has thanked: 14 times
Been thanked: 6686 times
Post by pedro »
Great images Marty
Astrophil
Been thanked: 581 times
Post by Astrophil »
They all turned out very well, Marty. Beautiful hi-res shots!
Phil
