Which etalon is better? Please, look, think and vote.
Has thanked: 13 times
Been thanked: 79 times
Post by Valery » Thu Oct 31, 2019 10:03 am
Hi all,
I need your little but important help, friends.
Here are two images which were taken not too far apart (in time) from the same location but through two different telescopes and different etalons.
Left image was taken with F/30 (on the etalon) and right image was taken with F/42 (on the etalon).
So, the question: which etalon you rate more narrow and more uniform?
Thanks for reading and your votes.
1 vs 2.png (1.11 MiB) Viewed 1567 times
Has thanked: 1081 times
Been thanked: 370 times
Re: Which etalon is better? Please, see, think and vote.
Post by Montana » Thu Oct 31, 2019 10:15 am
Absolutely marginal Valery but I reckon number 2 is slightly better. It is overall marginally more 3D (less flat) and the key for me is the plage to the right of the filament, it is very slightly brighter and more fluffy on the right indicating a tighter bandpass. It is marginal, both are fabulous.
Martin_S
Has thanked: 30 times
Been thanked: 125 times
Post by Martin_S » Thu Oct 31, 2019 11:10 am
I agree with Alexandra, number 2 shows better contrast and more detail.
Martin
H - alpha setup
Lunt LS60THa Tilt-Tuned Solar Telescope, LS50FHa solar filter front-mounted Double stack etalon. 2 x Barlow
Remote etalon and focusing control's ASI290mm Camera
White Light setup
Skywatcher ED72 ,ED100, Homemade solar wedge, IR cut filter, Solar Continuum filter.
Mounts
Skywatcher HEQ5 Pro Mount ..
Darkside setup
Skywatcher ED72 ,ED100, GSO RC6 ,Celestron Nexstar 6SE.
MalVeauX
Has thanked: 49 times
Been thanked: 64 times
Re: Which etalon is better? Please, look, think and vote.
Post by MalVeauX » Thu Oct 31, 2019 2:48 pm
Hi Valery,
Would you kindly check out my PM to you on here?
I think the etalon on the left is probably better. My reasons: It's nearly the same as the one on the right, at F42, yet it's doing it at F30. So if they were both brought to F42, the one on the left would be superior and more narrow. I'm specifically looking at the contrast on the fibrils, they're darker, slightly, on the right side image, to me being a little more selective and narrow band, just like filaments will be darker in that sense. Yet the F30 image is doing nearly the same thing, just nearly, at only F30. So if it were brought up to F42, it would likely be better. Uniformity seems to be essentially equal, everything looks onband in the same locations. There's a little super granulation peaking through on both maybe, to be expected with a single etalon like this.
eroel
Been thanked: 341 times
Post by eroel » Thu Oct 31, 2019 4:43 pm
Valery:
I like better the first one. (F/30)
I agree with Marty.
MAURITS
Been thanked: 14 times
Post by MAURITS » Fri Nov 01, 2019 8:59 am
Valery, I like the first,
It is indeed marginal between the two images, but in the first image I see some finer details in the middle field.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Sungazer
Post by Sungazer » Fri Nov 01, 2019 9:14 am
Hi Valery, After looking carefully,in my opinion the first one is more appealing,and has very slightly better definition. Though there is not a lot to of difference, probably a personal choice. I just wish my scope would be that good !!!! John. :bow
Has thanked: 1222 times
Been thanked: 497 times
Post by marktownley » Fri Nov 01, 2019 9:45 pm
Both look essentially identical to me Valery, there are small differences, but is not night or day. If one can do it at f30 then to me that is better than f42, just on the grounds of shorter exposure and better sampling.
bart1805
Post by bart1805 » Sat Nov 02, 2019 10:29 pm
I agree with Mark. Both excellent.
Post by Valery » Tue Nov 05, 2019 6:28 pm
Thanks to all who expressed his opinion.
Post by marktownley » Tue Nov 05, 2019 6:53 pm
How do you rate the etalons Valery?
Post by Valery » Wed Nov 06, 2019 2:44 am
My conservative estimation is that they are better than some expensive and larger 0,3A etalons.
