Enhancing filament detail
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Hi everyone now i'm double stacking my lunt LS60 I'm starting to see lots more detail in my Images. Yesterday's session yielded some nice wispy filaments. Is there a process in photoshop or any other software that could enhance the details that I have captured?. I imaged this with a 30 second capture in Firecapture, stacked in AS3, sharpened in Registax ,final processing was done in Photoshop.
Any advice would be greatly appreciated.
Martin
Martin
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Enhancing filament detail
Have you tried Imppg software, it's free for solar imaging.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9145 times
- Been thanked: 6027 times
Hi Martin: like stardust said, you should try ImPPG and definitely Astra Image.
- Martin_S
Thank you Franco and Stardust, I have a copy of imgPPG and will give it a try, Astra Image is one I haven't heard off so I'll check that one out too.
Martin
Martin
- Been thanked: 10248 times
You're getting some nice results there Martin!
- Been thanked: 4787 times
- Been thanked: 8793 times
These are super Martin, increasing the contrast will help too, try investigating the curves function in Photoshop.
- Been thanked: 4340 times
These are nice sharp images Martin!!!
Both programs mentioned do a great job on solar images, you will just have to put some time in to see which you prefer.
- Has thanked: 17581 times
- Been thanked: 16697 times
Lately enhancement is a good thing. The sun is very bland lately. Now if I can find a way to enhance things visually.
- Martin_S
Thank's everyone for your comments I will certainly try all the options mentioned.
Martin
Martin
- Been thanked: 4904 times
