Full Disk 2019-12-17
- JochenM
- Been thanked: 1619 times
- Has thanked: 9723 times
- Been thanked: 5773 times
Re: Full Disk 2019-12-17
Hi Jochen,
Starting to look good. What have you done so far ?
Is it a double stacked or single ?
- JochenM
Thanks Rainer. I think my main issue before was my pressure tuner not being sealed properly. I added some grease to the threads and immediately saw a huge improvement today. Other than that, practice makes perfect. But pretty happy with how today’s session turned out.
It’s a single stack LS50.
- Been thanked: 10489 times
Looking good, just work on that tuning to get an even disk Jochem
- JochenM
Thanks Mark/Maurits.
Tomorrow's supposed to be a beautiful sunny day here in Belgium, so plenty of time to get some more practice in.
- salvo lauricella
- Has thanked: 56 times
- Been thanked: 75 times
It's coming on nicely Jochen, but like Mark said, keep working on the tuning, look for the darkest contrast and then you know you are on band
- JochenM
- Been thanked: 4427 times
Hi Jochen...
Very nice first set of images...well done!!!
As others mentioned some fine tuning will help enhance he contrast and even the disk out. Unfortunately, we don't have a lot of active regions or filaments to experiment on.
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 757 times
Good job, Jochen!
To tease the max resolution out of these 50 mm, I suggest you make a 2x2 mosaic. I have similar pixel pitch (3.75 µm) to yours, and such mosaics work very well for me with a 2x Barlow's lens element screwed directly into camera's nosepiece (giving ~1.6x), e.g.:
- Been thanked: 4980 times
Jochen.
Very nice and clean FD´s for a 50mm aperture, probably you can improve your fine tuning adjustments.
- JochenM
Thanks for the feedback/tips everyone.
- JochenM
A mosaic is definitely something I'm aiming towards doing as well. But I want to make sure I get the single images perfected first (the whole walk before you run thing ).GreatAttractor wrote: ↑Wed Dec 18, 2019 3:45 pm Good job, Jochen!
Also, absolutely amazing image you linked there. Quite a spectacular result for such a modest little telescope.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Doing well Jochen.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
