halpha sun of December 29th
stef41
Has thanked: 124 times
Been thanked: 1487 times
Post by stef41 »
good morning, everyone,
on vacation, from the blue sky, the opportunity to draw his portrait to our star with minimalist activity!
As for the prominences, I found two of them by scrutinizing the first image (not seen with the eyepiece) and a very small active area where, it seems, a micro stain hides inside...
Apart from that, a sun not very high and a maximum of turbulence (hence a reduction to 75% of the images).
Otherwise, still at the fs60 with its sm40 double stack, glasspath x1.25, BF10 and zwo178mm on staradventurer around 11h30 UT.
Season's greetings to all
stéphane - France
dhkaiser
Has thanked: 1407 times
Been thanked: 899 times
Re: halpha sun of December 29th
Post by dhkaiser »
Thanks for the images.
Dan
South central Indiana
USA
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Looking good Stéphane. The AR is also still looking pretty crisp.
Jochen Maes
Belgium
https://www.jochenmaes.com
Has thanked: 20756 times
Been thanked: 10441 times
They came out well Stephane!
Has thanked: 17925 times
Been thanked: 8894 times
How lovely to have a holiday with blue skies :hamster: super image Stephane, what a beautiful active region :bow
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Hi Stéphane...
A good set of images even though the activity is low!!!
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Brilliant, the sun is so low from my home tree's and landscape buildings, etc get in the way.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
Well done Stephane.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
