Lunt LS60 DS – Testing a new toy
- Ronnie_Clayton
- Has thanked: 10 times
- Been thanked: 130 times
Hello friends!
Last week I did the first test with my new toy, a Lunt LS60 DS. I´ve liked it, but I´m having some challenges with “ghost discs” (more than I was expecting). Other issue occurs at right side of sun image (in the picture), there are some “rings” (like reflections) that I can´t eliminate (yet). It´s interesting because they appear just at the right side of image, I´ve tried rotate the camera, tilt the camera, adjust the etalons tuning but didn’t solved it…
This full disc images I did using a DMK51 camera
So, here are the equipment and the Sun pictures, I hope you enjoy !
- IMG_5937.jpg (1.15 MiB) Viewed 5545 times
- efc32ae3-542d-402f-be06-2b8fc543ece9.JPG (313.64 KiB) Viewed 5545 times
- 1459ff73-fa46-4d7c-b766-ccdfc13cb963.JPG (256.75 KiB) Viewed 5545 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Lunt LS60 DS – Testing a new toy
I think they're great image's. I to have a lunt 60mm pressure tuned DS. I've always first tuned the 60mm without the double stack then add the DS and tuned that. That's what lunt recommends. Not sure what else to suggest.
- IMG_20191229_142105.jpg (2.57 MiB) Viewed 5541 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Ronnie,
Your images look good to me, can't see the rings you speak of on my monitor. The photo of your setup is indoors, do you shoot through a window?
Dan
Dan
Dan
South central Indiana
USA
USA
- Ronnie_Clayton
Thanks guys!
Dan, I catch my pictures from my balcony (I live in an apartment). I keep the windows opened to do the job ;-)...
About the rings, I´m talking about it...
- Detail.jpg (106.91 KiB) Viewed 5527 times
- Been thanked: 4786 times
- dhkaiser
Yeah Ronnie I see them now. Don't know what would cause that, sorry. I still think your images are impressive.
Dan
USA
USA
- JochenM
- Been thanked: 1619 times
While I have nothing useful to say about the "ghost rings"; I do love the images. Nicely done!
- Has thanked: 20424 times
- Been thanked: 10242 times
Hi Ronnie! Nice shots and nice new toy. They almost look like a processing artefact to me rather than something to do with the scope.
- Ronnie_Clayton
Thanks Friends!
@Marktownley
At the first time I was thinking that it was some processing artefact too... But it appears during the capture, just on the right side of image/video. Yesterday I did some videos (I need to process to share here) and these rings appeared again...
@Marktownley
How have you got the edge of the sun brighter than it would appear normally? Also, are you running with gamma turned on with the camera?
- Ronnie_Clayton
Marktownley,
For the edge I use the Curves Tool. In the first image I´ve used the "curve toll" in a single layer (same curve for both edge and surface). For second image I´ve used the "curve tool" in two different layers (one for edge and other for surface).
About Gamma, normally I use Gamma enabled in my captures.
Ronnie
Ronnie
Ronnie,
You need a new b/w camera and you should use 16bit image data to get rid of these "rings".
- Has thanked: 9401 times
- Been thanked: 5558 times
Hi Ronnie,
Great images. Are you using Lucam Recorder for your Imaging Source Camera ?
Rainer
Rainer
Hi Dan,
I used to shoot the Sun through a window. I have not seen a difference between shooting through a window or without window.
This was my setup when I started with H-alpha imaging and had no Observatory. This was January 2008
- Ronnie_Clayton
Thanks for your help Valery. I have a Basler acA1920-155. I'll test it in my next session .
- Ronnie_Clayton
Thanks Rainer.
I am using Genika Astro as a recorder software for ImagingSource and Basler cameras.
Hi,Ronnie_Clayton wrote: ↑Tue Dec 31, 2019 12:04 amThanks Rainer.
How do you colour your images ? because it looks similar to what I do applying in real time a colur mask and no need for two exposures (Surface and Prominences)
- Has thanked: 17648 times
- Been thanked: 8787 times
These images look fantastic Ronnie you live at a dizzying height
When I first saw what you meant by the rings I thought instantly what Mark said. I get this same effect with the Solarscope and the Grasshopper 3 when the gamma is too high. I found a limit that I should never go over on the gamma to keep these down to a minimum and yes, I found it worse on one side than the other. Drop the gamma down or use a different camera but still don't increase the gamma too much.
- Ronnie_Clayton
Hello,rsfoto wrote: ↑Tue Dec 31, 2019 12:45 amHi,Ronnie_Clayton wrote: ↑Tue Dec 31, 2019 12:04 amThanks Rainer.
No secrets here :-). Basically I use Color Curve Tool for each color channel (RGB). I don´t use two exposures...
Ronnie
- Ronnie_Clayton
Thank you Alexandra!Montana wrote: ↑Tue Dec 31, 2019 10:47 am These images look fantastic Ronnie you live at a dizzying height
In my next tests I´ll use the tips commented by you, Mark and Valery
Ronnie
Hi Ronnie,Ronnie_Clayton wrote: ↑Thu Jan 02, 2020 12:10 pmHello,rsfoto wrote: ↑Tue Dec 31, 2019 12:45 amHi,Ronnie_Clayton wrote: ↑Tue Dec 31, 2019 12:04 am
Thanks Rainer.
Ronnie
So do you do this while straming the AVI or afterwards during processing ? I am asking because my existing software Lucam Recorder does only work with Lumenera = SkyNyx cameras or the Imaging source and I intend to go for ZWO in the future.
Thanks Rainer
- Ronnie_Clayton
rsfoto wrote: ↑Thu Jan 02, 2020 6:19 pmHi Ronnie,Ronnie_Clayton wrote: ↑Thu Jan 02, 2020 12:10 pmHello,
Ronnie
Thanks Rainer
Hello Rainer
For my images I use the following sequence:
01 - For Capturing: Genika Astro (in mono, SER format)
02 - For Stacking: Autostarkket (TIFF output file format in mono)
03 - For Editing (Deconvolution, contrast, etc (in mono)): AstraImage
04 - For Editing (false color, fine tuning, etc): Affinity Photo.
So, I apply the false color just in the final of editing process.
Ronnie
Hi Ronnie,Ronnie_Clayton wrote: ↑Thu Jan 02, 2020 6:50 pmrsfoto wrote: ↑Thu Jan 02, 2020 6:19 pmHi Ronnie,Ronnie_Clayton wrote: ↑Thu Jan 02, 2020 12:10 pm
Hello,
Ronnie
Thanks Rainer
Hello Rainer
Ronnie
Thanks a lot for the explanation as well as the patience with me
Rainer
- Ronnie_Clayton
Hello Rainerrsfoto wrote: ↑Thu Jan 02, 2020 8:10 pmHi Ronnie,Ronnie_Clayton wrote: ↑Thu Jan 02, 2020 6:50 pmrsfoto wrote: ↑Thu Jan 02, 2020 6:19 pm
Hi Ronnie,
Thanks Rainer
Hello Rainer
Ronnie
Rainer
I'm happy to share what I know to help you !
If you have more doubts don't hesitate to ask. We are here to learn more and more...
Ronnie
