Surprisingly I woke up to a clear sky, a cold snap came through here in Florida right after a really nasty storm cell down South. Seeing was not great, but worked out. Seeing averaged 1.8 arc-secs at best to 2.2 arc-secs when it was best on average, and peaked between 4~5 arc-secs when it was awful. Managed to get some data on what's left of AR2755. She was flaring today a little bit, here and there. The umbra is still visible, but diminished to two little pores basically after the light bridge split it up even more. It'll be gone soon.
Colored:
BW:
Equipment:
C8 Edge + Aries D-ERF
Baader Red CCD-IR Block Filter
PST Etalon + 10mm BF
ASI290MM
120mm F10 Frac
ASI290MM
AR2755 & Filaments, High Res & Wide Field | Jan 5th 2020
- Has thanked: 1171 times
- Been thanked: 1360 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: AR2755 & Filaments, High Res & Wide Field | Jan 5th 2020
Wonderful images, thanks!
Dan
South central Indiana
USA
USA
- Has thanked: 9412 times
- Been thanked: 5573 times
Hi Marty,
Great close up images
- The Sun?
- Been thanked: 2 times
Nice work
I’m ready to get out if it shines through for me
BD
BD
Lunt LS100THA / Double Stack /1800 BF / BF Heater
Denk Bino / W Power Switch
DM 6 alt/az / StellerVue Walnut Stablelock PierTripod
Well done Marty. Great set of images!
Clear and cold again tomorrow. Hope the seeing is better.
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
I know I'm repeating myself; but your closeup images are absolutely amazing. Nice work.
- Has thanked: 20438 times
- Been thanked: 10245 times
You got a great set of images there Marty, well done!
- Has thanked: 173 times
- Been thanked: 615 times
Well done mate!!
Just need the smoke haze to reduce and we may be able to see the Sun......
- Has thanked: 2412 times
- Been thanked: 4786 times
- Been thanked: 8791 times
These are fabulous Marty, a great set
