Full Disc 11 January 2020
- Has thanked: 9723 times
- Been thanked: 5773 times
Sunshine again and so here some full discs in H-alpha as well as White light. It is interesting to see that the old cycle 24 spot on the equator is not visible in WL but the new cycle 25 at about 30° South is visible in WL.
- Has thanked: 17853 times
- Been thanked: 16998 times
Re: Full Disc 11 January 2020
Rainer
Thanks for the Ha & WL views. I have cloudy rainy weather here today.
- JochenM
- Been thanked: 1619 times
- salvo lauricella
- Has thanked: 56 times
- Been thanked: 75 times
Very very good Rainer!
Salvo Lauricella
https://www.salvolauricella.it/
- Been thanked: 4429 times
Another beautifully detailed FD image Ranier
- Has thanked: 9326 times
- Been thanked: 6159 times
- Been thanked: 10491 times
Brilliant! Those polar filaments in both hemispheres are an indication cycle 25 activity is just below the surface.
Hi Mark,marktownley wrote: ↑Sun Jan 12, 2020 4:31 pm Brilliant! Those polar filaments in both hemispheres are an indication cycle 25 activity is just below the surface.
Thanks for that explanation. That is what I was going to ask if they mean something
This cycle 25 is my second cycle as I started around 2008
Rainer
- Been thanked: 4980 times
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Nice disc, how many details there !
Raf
Superb full discs
In WL you can only observe faculae at the limb, when the cycle 24 AR gets to the limb you will see it
Hi everybody,
Thanks for the comments
@Alexandra, Thanks for the info. I guess you mean cycle 25 AR ...
The one at the equator is cycle 24, it is in the middle, that is why you cannot see it in WL yet. When it reaches the limb you will see it's faculae too
Hi Alexandra,
Thanks. Did not correctly understand what you wrote and therefor I thought you were referring to the fact that when cyle 25 spots start to arise then I can see them.
Sorry for the confusion ...
