Full Disc 15 January 2020
- Has thanked: 9401 times
- Been thanked: 5561 times
High and thin clouds infront of the Sun but enough light so I thought to give it a try it and below the result. Sorry for the bad quality
If yout ake a look at the SDO magnetogram image you can see in the northern hemisphere a cycle 24 and a cycle 25 spot. The most left one is cycle 25
and below is how the Sun looked through the clouds.
- Been thanked: 4904 times
Re: Full Disc 15 January 2020
Rainer:
Nice result in spite of conditions, at home I had about the same problem (thin high clouds).
Fuerte abrazo,
Fuerte abrazo,
- Has thanked: 9144 times
- Been thanked: 6025 times
Hi Rainer: very nice results in spite of the thin clouds. Are you still using the Daystar filter? If you are, which one ?
- JochenM
- Been thanked: 1619 times
Good job managing to get that image (I think it's still good) in those type of conditions.
- Has thanked: 20424 times
- Been thanked: 10243 times
Excellent image, especially given those hazy skies, i'm hoping the weather allows me to get the solar scope out this weekend at some point.
- Has thanked: 17667 times
- Been thanked: 8787 times
Franco, somehow I don't think a full disc that superb came from a Daystar filter (sorry, am I allowed to say that?).
Rainer, another wonderful disc, you are very lucky to have that filter set
Hi Franco,
Sorry no. Both DayStar filters I bought in April 2018 has gone back to DayStar as both were blind. Everytime I read the word DayStar I get angry
That purchase was a total failure and even worse the way DayStar handled the complain. Weeks and weeks with no answers ...
DayStar is dead for me for all times ...
I have now only a very double stacked Coronado SM 60 with BF 30 ...
Rainer
Rainer: you are a magician ! You certainly are doing a magnificent job of full disks with the SM 60 double stacked. I wish I could do the same with my SM90 DS. The 90 is traditionally not easy to put in band due to the length of the scope: you need orangutan arms to tune the external etalon while you look into the eyepiece. Once it is band, though, the results are excellent.
Hi Franco,ffellah wrote: ↑Thu Jan 16, 2020 7:06 pm Rainer: you are a magician ! You certainly are doing a magnificent job of full disks with the SM 60 double stacked. I wish I could do the same with my SM90 DS. The 90 is traditionally not easy to put in band due to the length of the scope: you need orangutan arms to tune the external etalon while you look into the eyepiece. Once it is band, though, the results are excellent.
I am no magician. I have the advantage of being able to adjust very fine the etalons remotely while looking on my monitor. I made that 7 seven years ago.
Look here viewtopic.php?f=9&t=26907&p=243127&hili ... er#p243127
Below the drawings of the parts you need to machine. OK, then you need a 10mm stepper motor with high reduction gears, a bellow couples, a screw which changes the angle, and a stepper motor driver and a little piece of software to move the stepper motor step by step ...
Rainer
- salvo lauricella
- Has thanked: 56 times
- Been thanked: 75 times
- Been thanked: 4340 times
Hi Rainer...
You have certainly mastered the full disk mosaics with that scope. Superb image despite the cloud
