Maximum allowable file size for posting?
Martin_S
Has thanked: 20 times
Been thanked: 91 times
Post by Martin_S » Thu Feb 20, 2020 11:58 am
Would any of the moderators be able to give me some advice on the maximum allowable file size for posting?. I managed to capture my first animation
of today's large prominence, I captured 375 images at 20 second intervals till the clouds rolled in . here is a heavily edited Gif of 12 frames that I have put together to give you some idea how lucky I was image wise.
Martin
H - alpha setup
Lunt LS60THa Tilt-Tuned Solar Telescope, LS50FHa solar filter front-mounted Double stack etalon. 2 x Barlow
Remote etalon and focusing control's ASI290mm Camera
White Light setup
Skywatcher ED72 , Homemade solar wedge, IR cut filter, ND3.0 filter, #58 green filter
Mounts
Skywatcher HEQ5 Pro Mount ,Skywatcher AZGTi Mount.
Darkside setup
Skywatcher ED72 , GSO RC6
Has thanked: 650 times
Been thanked: 226 times
Re: Maximum allowable file size for posting?
Post by Montana » Thu Feb 20, 2020 12:17 pm
Hello Martin
There are no file size limits on the forum although we have a total storage space of 28GB and we have used 24GB already. So if we have only 4GB left and you upload a file 500MB in size you can tell how long we are going to last. Please be sensible, that is the rule.
Tiff images don't open so if anyone uploads a big Tiff and leaves it unopened this is what fills our space unnecessarily.
We try to encourage folks to upload their huge Gifs to places like Flickr or Astrobin and then link it through to here if possible, then they take the storage and we enjoy the images :) if you need help with linking then please do ask.
pedro
Has thanked: 1 time
Been thanked: 163 times
Post by pedro » Thu Feb 20, 2020 1:58 pm
Hi Martin
Alexandra said it all.
I always post links of my images (webpage or FLICKR).
It is very important to take into account the limit we have as far as storage goes (4Gb left is very low)
eroel
Been thanked: 187 times
Post by eroel » Thu Feb 20, 2020 4:34 pm
Martin:
A very nice first animation.
Has thanked: 53 times
Been thanked: 34 times
Post by ffellah » Thu Feb 20, 2020 5:51 pm
I knew you were going to be very good at this, Martin.
Well done !
Franco :bow :bow
Has thanked: 314 times
Been thanked: 276 times
Post by DeepSolar64 » Fri Feb 21, 2020 5:03 am
Martin,
I noticed the large prominence on the GONG images today but could not observe it due to cloudy snowy weather. You brought it to life for me!
Thanks
Post by DeepSolar64 » Fri Feb 21, 2020 5:10 am
Alexandra,
What happens when the storage limit is reached? It probably will be reached in time. Do images get deleted, posts get deleted or does the forum obtain more space? At my job we save data, in images and otherwise and after awhile the server fills up. They usually delete the oldest data until they have freed up adequate space to run for an indefinite time longer. FIFO. Then it is delete and start again...
Post by Montana » Fri Feb 21, 2020 8:05 am
I have no idea James, that will be up to the big man to decide. I think he said the largest file sized images would go first and at least try to remove all the redundant Tiff files that don't open anyway :)
Martin_S
Post by Martin_S » Fri Feb 21, 2020 10:04 am
Thank you all for your comments . Alexandra I created a Flickr account for my animations and large files. This was my first attempt, here are the results.
https://www.flickr.com/photos/187059261 ... ed-public/
Martin
H - alpha setup
White Light setup
Mounts
Darkside setup
Post by Montana » Fri Feb 21, 2020 10:05 am
That's fabulous Martin :hamster:
What file type is it? just trying to link it here. When it is an animated gif (save for web and devices) the BBcode links through to here but this doesn't.
I see it is an MP4, still looking how you link
I have asked Mark, he is the whizz tech guy :)
Martin_S
Post by Martin_S » Fri Feb 21, 2020 11:20 am
Alexandra, I converted the GIF file to an MP4 as it was a smaller file size. If a Gif is a better option please let me know, as I'm not tech savvy on social media platforms.
Martin
H - alpha setup
White Light setup
Mounts
Darkside setup
Post by Montana » Fri Feb 21, 2020 12:10 pm
Its OK Martin, I'm wondering if you can't link an MP4 here but then I am not that great with computers so I may have missed it, Mark will know.
In Photoshop I usually "save for web and devices" and choose gif then pick a reasonable size like 1000 pixels wide or 1500 pixels wide, then click save. When you upload this to Flickr it won't run from the photostream page but don't worry, if you go to 'view sizes' then pick 'original' it will play. When you go to 'share' pick BBCode, then pick Original (size), copy this BB code and paste it into the forum subject box, it will then play in a window in your post. It helps if you loop the animation so it keeps going otherwise folk will miss it and it will be over.
Ross
Post by Ross » Fri Feb 21, 2020 2:21 pm
:hamster:
rsfoto
Has thanked: 282 times
Been thanked: 259 times
Post by rsfoto » Fri Feb 21, 2020 3:56 pm
Yes that is a way to get an image with less kilobyte but one should take into consideration that for example if my image is 2000 x 2000 pixel and has a certain size changing its pixel size to 1000 x 1000 will also reduce your details of the original image.
It is by far better to leave the image at its original pixel size and use instead the compression factor.
My images of about 2300 x 2300 pixels using a compressión of 60% are about 1 MB and at 100% they were 3.3MB. You can check in real time how the compression percentage affects your image and then decide for a compressión.
As you cans ee in my images i have not lost details and no compression artifacts are showing up.
Compressión artifacts are those square blocks or pronounced jaggy lines where you clearly notice brightness differences.
Rainer
