today the new Double Stack filter for my Lunt 60 arrived, and of course it is raining
Probably most of you remember that some months ago I received a double stack filter that was decontacted
I sent it to the shop and the shop sent it to USA for repair…
This is the new one and hope everything will be ok this time.
I hope everything will be fine for you too.
Double Stack filter for Lunt 60 arrived!
- salvo lauricella
- Has thanked: 56 times
- Been thanked: 75 times
- Been thanked: 4427 times
Re: Double Stack filter for Lunt 60 arrived!
Congrats on receiving your replacement filter Salvo. Hopefully the weather clears and gives you a chance to try it out!!!
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Yay
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20819 times
- Been thanked: 10489 times
Hope it's a good one Salvo!
That's very exciting, lets hope the Sun shines on you so you can try it out, fingers crossed
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
- Been thanked: 4980 times
Salvo:
It is really nice to share our feelings when we receive a new or old accessory, that is the only time that we look with attention the boxes, housings etc.. and we think, I will keep the shipping box...
Enjoy your toy and show us how it performs.
Saludos,
Saludos,
- Has thanked: 17853 times
- Been thanked: 16996 times
Salvo,
Lunt Solar Systems is awesome. I have always heard their customer service is good. And the etalon came in a nifty little case. My Meade Coronado etalon came in a cardboard box without such a case. That alone says a lot for Lunt. While I do like my Coronado SM II 60, if I did it again I would go Lunt. I believe Lunt has an edge over Meade Coronado in a number of ways.
Congratulations and clear skies!
- salvo lauricella
Thank you guys, I will tell you something when I will try it. It is raining today and for all week :-(
Salvo Lauricella
https://www.salvolauricella.it/
