All,
Here are my visual solar observations for today. The skies are partly cloudy. I had trouble seeing anything today and had to tease out details. It seemed I had trouble getting the etalons on-band.
Coronado SolarMax II 60 DS. 16x and 21.5x ( Ha )
With certainty I could see 2 small filaments. I thought I might have seen 2 more but never could re-find them. I thought I could make out a tiny white plage but going back again to look for a second time I could not find it again. One prominence visible. Faint. I thought I glimpsed a second. But again upon second look nothing. Hmmm... Chromospheric filagree visible across disc.
Was I looking too hard? The GONG image shows two easier filaments and one prominence I should have been able to see.
Orion 70mm Solar Telescope. 25x ( WL )
Sun spotless. No detail.
3-26-2020 Observations
- Has thanked: 17572 times
- Been thanked: 16694 times
- latest_gong_color.jpg (614.73 KiB) Viewed 3106 times
- Has thanked: 20438 times
- Been thanked: 10245 times
Re: 3-26-2020 Observations
Good report. The sun was quiet today, but it was nice to get out in it.
Mark,
Very quiet. It's a challenge to see any detail.
- Has thanked: 8418 times
- Been thanked: 8162 times
Thanks for the observations, James.
The British Astronomical Association website (Solar section) provides tips on observing and accurately recording solar features. Might be helpful. Tilting Sun software is also excellent as a means of providing a set of gridlines so that features can be accurately positioned on or around the disk. There’s quite a skill to accurately describing what’s happening on the Sun. I admire your efforts here.
Stu,
Being able to accurately draw what you see is a big plus. Tilting Sun could be used on an accurately drawn disc for orientation or could be used as a grid to draw the disc in the correct orientation. Still, my drawing skills are not that great. I guess that is why I decide to describe what I see. An accurate drawing or sketch would be so much more informative. Or photographs as you do! You can't beat imaging as a way of documentation.
Thanks: James
Thanks: James
- Has thanked: 2412 times
- Been thanked: 4786 times
Today wasn't much better. One prominence and what I thought were three tiny nearby filaments. Clouds moved in and I never had a chance for a more thorough look. The sun sure is calm.
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
- Been thanked: 8791 times
Sounds like a bit of a struggle today, I get that sometimes when it seems nothing quite is how it should. When you are looking for such fine structures you will always have to look hard, think how expert you will be when it is solar maximum and you are used to observing all these tiny features, you will end up with an A4 essay
Very true!! Learning solar observing skills can be honed during minimum making maximum a blast! I learned deep sky observing at first using 50 and 60mm refractors. It made using larger reflectors a breeze!Montana wrote: ↑Sat Mar 28, 2020 2:36 pm Sounds like a bit of a struggle today, I get that sometimes when it seems nothing quite is how it should. When you are looking for such fine structures you will always have to look hard, think how expert you will be when it is solar maximum and you are used to observing all these tiny features, you will end up with an A4 essay
