WL from 11th April
Freddie
Has thanked: 38 times
Been thanked: 185 times
WL from 11th April
Post by Freddie »
Some random surface detail captured at 11.30 yesterday.
Freddie
Ha: 152mm, Quark, ASI174m
WL: CPC9.25, ASI120m
Has thanked: 20732 times
Been thanked: 10427 times
Re: WL from 11th April
That's a beauty Freddie! What equipment did you use for this?
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Excellent shot !
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Excellent WL image Freddie
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
allhoest
Has thanked: 714 times
Been thanked: 496 times
Post by allhoest »
Excellent Freddie.
I come with the same question: can you provide details about your setup.
Thank you.
CS
Alex
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
That's some nice granulation there, Freddie. Looks great.
Jochen Maes
Belgium
https://www.jochenmaes.com
Has thanked: 17807 times
Been thanked: 16940 times
Post by DeepSolar64 »
WoW!!! Awesome!! That is one of the best solar granulation convection images I have seen on here. That's some insane resolution. What scope/equipment did you use, Freddie??
I bet some colorization and contrast adjustment would bring out even more detail.
Freddie
Post by Freddie »
Thanks for your kind comments. Posted in a bit of a rush this morning so sorry for the lack of info.
This was taken from my back garden in Kent using my CPC9.25. I use Baader 3.8ND film (I also have some 5.0 but the 3.8 is so much better for imaging) a 2x Barlow and my ASI120mm-s. I have locked the std focuser and added an aftermarket focuser to the VB. With everything in place this works out at ~5m FL. Captured using FireCapture then processed in AS!3, Imppg and PS.
Freddie
rsfoto
Has thanked: 9677 times
Been thanked: 5750 times
Post by rsfoto »
Excellent resolution
Has thanked: 64 times
Been thanked: 4406 times
Post by MapleRidge »
Outstanding resolution Freddie...well done :bow
Freddie
Post by Freddie »
Thanks for your kind comments guys.
Freddie
Freddie,
Was you using a continuum filter?
Has thanked: 17888 times
Been thanked: 8887 times
This really is superb!! I get weak at the knees when I see beautiful granulation :bow :bow :hamster:
Freddie
Post by Freddie »
Thanks for your kind comment Alexandra.
James, this isn’t with a continuum filter. I have one in my filter wheel but have never got on with it. By it’s own or with an IR cut we just never clicked.
What I found was that using the Baader green filter (it’s the manual filter wheel I use for planetary imagining so has a full set of Baader LRGB imaging filters along with various others) gave better results. The green filter is centred roughly at the same wavelength as the continuum but has a wider band. I found that the loss of some contrast, which wasn’t much to be honest and can always be compensated for in post processing, was far out weighed by the greater light pass the filter gave, allowing significantly shorter exposures and or lower gain settings. For me, the ability to reduce exposure/gain was far more important at the image scale I use than a bit of contrast. The other critical thing is to use the 3.8ND film as the 5.0ND just doesn’t allow enough light through.
Freddie
Martin_S
Has thanked: 999 times
Been thanked: 3060 times
Post by Martin_S »
Great results Freddie, thanks for sharing them.
Martin
