Okay seeing (fluctuating around 2-3 arcseconds) and some clouds here yesterday, but with enough gaps in between, so I tried to zoom in on the active regions as far as I could get with 90mm. First a one-shot disk (full resolution here: https://live.staticflickr.com/65535/499 ... 9f51_o.jpg):
Then a two pane mosaic, with less than perfect flats, so you see the seam (full resolution: https://live.staticflickr.com/65535/499 ... 8c05_o.jpg):
And the two active regions in detail:
(Full resolution: https://live.staticflickr.com/65535/499 ... 3e43_o.jpg and https://live.staticflickr.com/65535/499 ... 1077_o.jpg)
Kind regards,
Frank
h-alpha, May 19th, 2020
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: h-alpha, May 19th, 2020
Nice Frank, can see the filaments over the AR.
Dan
South central Indiana
USA
USA
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Great shots, Frank. Nice to see the filament on the first FD. Can't see the filament in CAK though.
Alfred
Alfred
- Been thanked: 4980 times
- Has thanked: 9723 times
- Been thanked: 5773 times
Very good images
Hi Frank, very nice images and i have been watching and imaging that small black/pointed area near the upper AR and in the upper central region, over the last three days. I thought at first that it might be something on one of my cameras or scopes, but clearly when moving the scope it was as-is.
I wonder if other have seen this, as it doesn't appears as a Sun-spot, so perhaps (jockingly) a UFO has successfully landed there !!!
Regards
Regards
- JochenM
- Been thanked: 1619 times
Oh yes! the full resolution discs are the ones to view in full res the join doesn't stand out too badly, how have you joined them? there are several free stitching softwares if you don't have Photoshop that should remove that seem.
https://stargazerslounge.com/topic/3543 ... programme/
Thanks everybody!
Alexandra, thanks for the link! I'm using Gimp to stitch the panes together by hand. When I tried to do a mosaic half a year or so ago I spent an afternoon or two to try out several softwares, but nothing really worked, so I ended up with Gimp. The mosaic above, however, puts together two images that were taken through slight haze, so are not really illuminated evenly, even with flats applied, so maybe not really feasible. In any case pushing the panes around in Gimp pixel by pixel is a bit cumbersome, so next time I'll probably give Autostitch another try!
Terry, interesting observation! I'll keep an eye open for further Klingon, Vogon or any other spacecraft on the sun or nearby!
Frank
Frank
- Been thanked: 10489 times
Good shots FRank, glad the sun is shining for you!
