Full disk 17-06-2020
- Has thanked: 9401 times
- Been thanked: 5561 times
Sunshine, warm but not too warm and here todays Sun with a new spot in the Northeastern quadrant at about +19° near the limb. Looking at the magnetogram from SDO it has cycle 25 polarity -/+. Let us see if it develops or if it just a tiny spot.
A few prominences, a disappearing filaprom and many filaments on the Sun's surface.
Inspired by the message from Dan Kaiser viewtopic.php?f=4&t=28511&p=259948#p259637 I added a L filter from Astronomik which is a IR/UV cut filter. First thing I noticed is that I had to increase in White Light my exposure time from 4.25 ms to 7.5 ms.
Below the result and IMHO the differences between Yes IR/UV and No IR/UV filter is barely noticeable. Perhaps it changes when we have spots as at the moment the Sun is totally blank. The tiny spot in the Northeastern quadrant did leave a footprinf in WL with the IR/UV filter but is not visible in the No IR/UV filter image but on the other side in the No IR/UV image I see a bit more plage in the Northern and Southern pole.
Difficult to say with a Blank Sun
No IR/UV filter
Yes IR/UV filter
No IR/UV filter
Yes IR/UV filter
Re: Full disk 17-06-2020
I did now combine half and half and noticed the Yes IR/UV filter has lost a bit of its 3D appearance compared to the No IR/UV filter.
The 3D gradient on the right side is better visible and by far less on the left side of the image.
The Yes IR/UV image looks now more similar to the SDO WL image. It looks somehow flatter.
SDO WL image from today.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Interesting comparisons, don't know what to make of them.
Dan
South central Indiana
USA
USA
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Interesting, have never done the comparison on a full disk but have compared UV/IR cut vs no UV/IR cut on higher magnification shots and seen the benefits.
David
- Has thanked: 9144 times
- Been thanked: 6024 times
- Been thanked: 4904 times
Rainer:
Very interesting difference and very nice shots.
Fuerte abrazo,
Fuerte abrazo,
- Has thanked: 17666 times
- Been thanked: 8787 times
Beautiful images Rainer
It may be that you have a very good quality refractor Rainer, the UV/IR cut filter is not necessary for all. It certainly is not necessary for the TEC140, but generally it helps for most telescopes. You are not required to use one, just check it out to make sure you aren't missing a trick
- Has thanked: 20424 times
- Been thanked: 10243 times
Great images and interesting thread Rainer.
I was surprised at the reduction in exposure time you experienced given the transmission curve suggests 95% transmission. I'm currently awaiting delivery of the L1 version of this filter to use as a sub aperture ERF as (according to the transmission data from Astronomik!) it should let through more light than the Baader blue I currently use.
I think the use of a UV/IR filter with the continuum comes from there are 2 versions of the continuum filter. Early versions have a huge IR leak as can be seen in the transmission curve below, it's effectiveky transparent above about 800nm, where our cameras are still very sensitive.
It is this IR leak that causes the low contrast when imaging.
You can see here there appears to be a later generation of the filter viewtopic.php?t=16944
Now without doing a direct comparison between old and new I wonder if the new version has a UV/IR coating as standard? Hence the result you found Rainer? How old is your filter?
Hi Mark,marktownley wrote: ↑Thu Jun 18, 2020 9:50 am Great images and interesting thread Rainer.
I bought my Baader Herschel wedge perhaps 11 or 12 years ago and so it is old, very old. It is the cheap metal sheet wedge.Now without doing a direct comparison between old and new I wonder if the new version has a UV/IR coating as standard? Hence the result you found Rainer? How old is your filter?
I will wait until some spots arrive and then make another comparison. It is question of two minutes to take off or put on the filter so not a big deal.
Hi Alexandra,Montana wrote: ↑Thu Jun 18, 2020 7:27 am Beautiful images Rainer
I am using a Takahashi FS-78 f/8.1 630 mm focal length scope which is a doublet and one lens is Fluorite ... ¿ is that good ?
Are you not using a continuum filter Rainer?rsfoto wrote: ↑Thu Jun 18, 2020 3:10 pmHi Mark,marktownley wrote: ↑Thu Jun 18, 2020 9:50 am Great images and interesting thread Rainer.
Hi Mark,marktownley wrote: ↑Thu Jun 18, 2020 6:00 pmAre you not using a continuum filter Rainer?rsfoto wrote: ↑Thu Jun 18, 2020 3:10 pmHi Mark,marktownley wrote: ↑Thu Jun 18, 2020 9:50 am Great images and interesting thread Rainer.
Sure there is a Continuum filter as as well a ND filter in the path.
Is the continuum filter an old or new one?
Hi Mark,
As old as the wedge
