August 4: H alpha series
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hi Everyone.
A few days of beautiful weather with relatively good seeing. I was able to do an extensive spectroheliograph run on the 3rd and here are the results of some H-alpha imaging on the 4th. The equipment: Aries ERF, Celestron C8 Edge, Moonlite CHL focuser, Daystar QPE 0.6A, Point Grey USB3 Grasshopper IMX174. Homemade optics give ~ f/46 telecentric at the Daystar filter and optional focal reduction to ~ f/30 when required.
Hope you enjoy!
Peter.
AR12770 at f/46 (two different exposures / treatments and an inverted image.)
The images should be left-right flipped for correct orientation.
AR12769 at f/46 (two different exposures / treatments and an inverted image.)
NE Limb prominence at f/30.
AR12769 and AR12768 panorama (6 panes), imaged at f/30. A large file! (correct orientation)
AR12770 at f/30 imaged on and off band.
Hope you enjoy!
Peter.
Re: August 4: H alpha series
Beautiful images, Peter. Very enjoyable and nice to see what's going on. Thanks.
Excellent high resolution images, Peter!
Nice to see the sun with higher activity.
Any chance you will image the sun at Ca II I 8542,1A with your spectroheliograph?
- Has thanked: 141 times
- Been thanked: 240 times
Gorgeous! 3D
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- Has thanked: 1188 times
- Been thanked: 1382 times
- Has thanked: 9710 times
- Been thanked: 5769 times
Hi Peter,
Excellent close up images of those spots. Well done.
- Has thanked: 20779 times
- Been thanked: 10462 times
Very good indeed Peter!
- Has thanked: 17970 times
- Been thanked: 8904 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- krakatoa1883
- Has thanked: 153 times
Great images, Peter, H-alpha is really 3D... Any detail about your telecentric ?
- p_zetner
Thanks for the kind comments, everyone!
Alexandra: I was pretty pleased with the "fluffiness" and the detail in the prom. Seeing makes all the difference.
Valery: I've just posted a full disk image, in the Solar Radio, Magnetometry and Spectroscopy section, taken in one of the CaII triplet lines (8498 A). I think I know what you're looking for. Some of the professionals observe a CaII triplet chromosphere which looks like a hybrid of H alpha and Ca K. This is probably only detectable at high image resolutions.
Raf: I've attached a photo and schematic of the telecentric. It's a train of four achromatic doublets: -80mmfl, -120mmfl, -120mmfl and +120mmfl. Let me know if you'd like more detail. The optics train in the photo is longer than necessary. There is an extra extension tube between the Daystar filter and the 2" eyepiece holder. I normally don't use this and should take a new photo! The focal reducer is simply a 300mmfl achromatic doublet held in the tube (to which the camera is attached) which slides into the eyepiece holder.
Peter
Peter
- Has thanked: 8543 times
- Been thanked: 8278 times
Excellent images, Peter. Lots of lovely fine details resolved in those close views.
That’s an impressive setup.
