10th September'20 Captures and a Prom in Cal-K too
- Been thanked: 4900 times
An interesting day for trimming-up adjustments of the three scopes, but still more to do with WL.
As was mentioned here the other day, a prom in Calcium-K is possible and by chance the same occurred with my Lunt 60mm scope albeit very faint, I will try that again by simple adjustment of the brightness from the camera.
Seeing conditions today were quite good and steady except for those white fluffy things on occasions...
Hopefully more improvements in the offing...
Thanks for looking
Thanks for looking
- 2020-09-10 1144z CAK-PROM-2.jpg (38.58 KiB) Viewed 427 times
- 2020-09-10 1144z CAK-PROM.jpg (67.55 KiB) Viewed 427 times
- 2020-09-10 1013z x200.jpg (49.71 KiB) Viewed 427 times
- 2020-09-10 1008z Ha.jpg (228.57 KiB) Viewed 427 times
- 2020-09-10 1004z CAK.jpg (123.19 KiB) Viewed 427 times
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
Re: 10th September'20 Captures and a Prom in Cal-K too
That CaK prom already looks pretty promising, Terry. Nice work.
Looking forward to more.
Thanks you Jochen.
Cal-K is my fav instrument and has always worked well with ease too..
Cheers
Cheers
- Has thanked: 17853 times
- Been thanked: 16997 times
Very nice Terry. The CaK image is my favorite. Your limb prominence image looks a lot like my iPhone ones but a bit sharper. I have never been able to get the iPhone to show the mottling as well as your second image does.
- Has thanked: 9321 times
- Been thanked: 6157 times
Nicely done, Terry. Same as James, the CaK is my favorite.
Thank you Franco and James.
I think many of us will agree that the Cal-K images are perhaps the best of, but of course Ha-proms can easily equal or beat Cal-K on occasions.
When there is some Sun-spot activity, I hope to make the final adjustments to the WL scope - making for the three together. Then more work and learning - using say FireCapture and other processing programs...
CLEAR SKIES
CLEAR SKIES
- Been thanked: 4980 times
Terry:
A very nice and fruitful session.
- Been thanked: 8906 times
Well done Terry! getting the faint CaK prom is a real challenge super images!
Thank you Alexandra and will hopefully improve on the next available occasion
Thanks Eric
Regards to you both
Thanks Eric
Regards to you both
- Has thanked: 20819 times
- Been thanked: 10489 times
Good job Terry!
