Sunday offered an clear sky that lasted through the day and into the night, so no limits from clouds on the solar captures unlike the day before. Seeing was better than average too, which helped to pull more details out of the higher resolution images. It was also a very nice day at the scope with temps pushing 20C near noon
The first images are the full disks...starting with Ha through the LS80T/LS75FHa/B1800Ha solar scope and ASI174MM camera: The full disk WL and CaK images were taken through the Stellarvue 110 with a Lunt Solar Wedge/Baader Continuum Filter for the WL and a modified Lunt Solar Wedge/B1800CaK/Baader K-Line filter with the ASI1600MM camera: I added the 5x Powermate ahead of the camera for these high res image of AR2781 using the same filters as above: AR2781 was still the prime target, and was imaged through the modded CR-150/DSII/B1800Ha + 2.7x Telecentric and ASI174MM for this multi frame mosaic: AR2780 still deserved an image too
As always, questions and comments are always welcome!
