Sol from the 9th of January 2021.
Been thanked: 4904 times
Post by eroel »
Hi:
Today started nice it was clear and sunny, but the neighbor tree was on the way, so had to wait and when the Sun was high enough to clear the tree, then clouds came with as lot of wind, so had to keep waiting for small gaps to take some shots.
Here is the result and thanks for looking.
Have a nice Sunday.
Sol del 9 de enero del 2021-Meade-CaK-PSTmod-1pos.jpg (948.94 KiB) Viewed 285 times
Sol del 9 de enero del 2021-Meade-CaK-PSTmod-1neg-pos.jpg (1.01 MiB) Viewed 285 times
Sol del 9 de enero del 2021-Meade-CaK-PSTmod-1pos-neg.jpg (959.74 KiB) Viewed 285 times
Sol del 9 de enero del 2021-Solarmax 90-DS-BF30-1pos.jpg (909.07 KiB) Viewed 285 times
Sol del 9 de enero del 2021-Solarmax 90-DS-BF30-1neg-pos.jpg (975.38 KiB) Viewed 285 times
Sol del 9 de enero del 2021-Solarmax 90-DS-BF30-1pos-neg.jpg (888.38 KiB) Viewed 285 times
Sol del 9 de enero del 2021-Stellarvue-Daystar-1pos.jpg (1.82 MiB) Viewed 285 times
Sol del 9 de enero del 2021-Stellarvue-Daystar-2pos.jpg (1.6 MiB) Viewed 285 times
Sol del 9 de enero del 2021-Stellarvue-Daystar-3pos.jpg (1.78 MiB) Viewed 285 times
Sol del 9 de enero del 2021-Stellarvue-Daystar-4pos.jpg (1.59 MiB) Viewed 285 times
Sol del 9 de enero del 2021-Stellarvue-Daystar-5pos.jpg (1.62 MiB) Viewed 285 times
9 enero 21.jpg (179.77 KiB) Viewed 284 times
Has thanked: 20442 times
Been thanked: 10248 times
Re: Sol from the 9th of January 2021.
Mighty fine shots Eric, especially given those tempestuous clouds.
Has thanked: 8418 times
Been thanked: 8165 times
Great images, Eric. Fantastic proms.
Has thanked: 17672 times
Been thanked: 8793 times
Excellent! what is interesting is that the prominence seems to be much more prominent in CaK than H-alpha, that is quite unusual, obviously quite energic :bow :hamster:
Has thanked: 64 times
Been thanked: 4340 times
Post by MapleRidge »
Excellent image Eric...well done!!!
You CaK setup really performs on the proms...I can only get them on occasion with my Lunt filter.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Fab prom images Eric.
Watch for the S.E.Limb where a spot may be emerging...
Cheers
MAURITS
Has thanked: 2412 times
Been thanked: 4787 times
Post by MAURITS »
Super Eric.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Post by eroel »
Alexandra, Mark, Stu, Brian and Terry, thanks for the feedback.
Alexandra and Brian, concerning the CaK shots, well what I do is to overexpose the prominence recording using a low Gamma, then after aligning and stacking 25% to 30% of the best recordings from a 600 frame video, I use the Lazzo tool to separate the protuberances so to get the background black, then with the lazzo tool I use levels over each protuberance so to get the backgound leveled, finally I make a composite with the surface image and keep processing to get the final image.
You can see the settings I use from the 2 photos taken of the recordings using Lucam-Recorder, hope it helps.
Best regards to all and let keep us safe.
