Sol from the 16th of January 2021.
eroel
Been thanked: 4957 times
Post by eroel »
Hi:
Again bad weather, very early I had to close, it clouded all over and rained.
With some patiente, again I got some shots through gaps with haze and clouds running by.
Thanks for looking and have a nice Sunday. (At my place is a Clouday).
Best wishes to all,
Sol del 16 de enero del 2021-Meade-CaK-PSTmod-1pos.jpg (864.8 KiB) Viewed 451 times
Sol del 16 de enero del 2021-Meade-CaK-PSTmod-1neg-pos.jpg (921.4 KiB) Viewed 451 times
Sol del 16 de enero del 2021-Meade-CaK-PSTmod-1pos-neg.jpg (845.26 KiB) Viewed 451 times
Sol del 16 de enero del 2021-Solarmax 90-DS-BF30-1pos.jpg (966.91 KiB) Viewed 451 times
Sol del 16 de enero del 2021-Solarmax 90-DS-BF30-1neg-pos.jpg (1.1 MiB) Viewed 451 times
Sol del 16 de enero del 2021-Solarmax 90-DS-BF30-1pos-neg.jpg (999.36 KiB) Viewed 451 times
Sol del 16 de enero del 2021-Stellarvue-Daystar-1az.jpg (2.02 MiB) Viewed 451 times
Sol del 16 de enero del 2021-Stellarvue-Daystar-2az.jpg (2.01 MiB) Viewed 451 times
Sol del 16 de enero del 2021-Stellarvue-Daystar-5pos.jpg (1.77 MiB) Viewed 451 times
Sol del 16 de enero del 2021-Stellarvue-Daystar-6pos.jpg (1.74 MiB) Viewed 451 times
Sol del 16 de enero del 2021-Stellarvue-Daystar-7az.jpg (1.95 MiB) Viewed 451 times
Sol del 16 de enero del 2021-Stellarvue-Daystar-7az-a.jpg (1.88 MiB) Viewed 451 times
Sol del 16 de enero del 2021-Stellarvue-Daystar-8az.jpg (1.85 MiB) Viewed 451 times
Sol del 16 de enero del 2021-Stellarvue-Daystar-8az-b.jpg[/attachment [attachment=15]16 enero 21.jpg
Sol del 16 de enero del 2021-Stellarvue-Daystar-8az-b.jpg (1.93 MiB) Viewed 451 times
16 enero 21.jpg (174.46 KiB) Viewed 451 times
rsfoto
Has thanked: 9677 times
Been thanked: 5757 times
Re: Sol from the 16th of January 2021.
Post by rsfoto »
Hola Eric,
Well done. I think finally today I will be able to do some Sun imaging again ...
Has thanked: 20738 times
Been thanked: 10436 times
You got a great set there Eric considering the weather. My seeing graph looks like yours.
Has thanked: 17924 times
Been thanked: 8889 times
Great to see the little spot on the CaK disc and some lovely Halpha close ups :hamster: :bow
I had a very cloudy weekend :(
eroel
Post by eroel »
Alexandra, Rainer and Mark:
Thanks again for looking, hope that some of you Rainer can see the Sun, at CDMX no way, all clouded and cold (well 16° Celsius).
Mark, it is hard to be observing the monitor and when you see an image start recording it, sometimes you can not get a full recording.
Well all this it is part of the hobby, you should see how it was when just chemical photography existed. :o
HAVE A SAFE AND NICE DAY.
LTHB
Been thanked: 581 times
Post by LTHB »
That's a very nice set of images, given the weather conditions!
Frank
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
My favs are the FD's and the prom captures Eric, so well done with your patience.
Thanks vm & Cheers
yltansg
Has thanked: 1455 times
Been thanked: 1444 times
Post by yltansg »
Hi Eric,
Your patience has paid off with these fabulous images!! Your posting reminded me again that there are always windows of opportunity even if it is a cloudy day :)
Alfred
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Excellent images Eric :bow
This seems to be a day to grab images between clouds ;)
Has thanked: 17807 times
Been thanked: 16948 times
Post by DeepSolar64 »
Stunning work Eric!
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Well done Eric.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Wonderful result!
Marios S.Ioannou
Sketcher/Visual Observer
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Exceptional images in very challenging conditions, Eric. Very nicely done.
