Solar Discs | CaK & 395nm | Jan 31rst 2021
- Has thanked: 1188 times
- Been thanked: 1382 times
Heya,
Pretty blank disc today! Just a few filaments and a single prom. So, focused on just testing a new approach to a full disc in shorter wavelengths using angular resolution. I'm using 3D printed masks (thanks Dave for the masks!!) to make a 60mm F16.67 long refractor for the very long focal-ratio to put it through the narrowband filters. In this case, a Lunt CaK 2.4A filter and an Altair 395nm 70A filter. Testing results on an IMX253 sensor (3.45um pixels, 1.1" sensor size for easy full discs). Seeing was decent, not great, very, very windy today, but it's the first clear morning I've had in a long time with all this nasty rain. Seeing was sub-arc to 2" back and forth with the wind. Graph provided.
Discs from the above in CaK (lower chromosphere) & 395nm (photosphere):
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: Solar Discs | CaK & 395nm | Jan 31rst 2021
Those are excellent images of a really quiet sun.
Dan
South central Indiana
USA
USA
- Has thanked: 9723 times
- Been thanked: 5773 times
Hi Marty,
Well done.
Well done.
Yes Marty, some fabulous images showing what has been happening today during the sleepy-Sun.
Cak is my fav and thanks for sharing
- Has thanked: 17849 times
- Been thanked: 16992 times
Very nice Marty! The 395nm images turned out well. The resolution looks good. Granulation is easily seen and a couple of pores are visible in the full sized image. Pretty darn good to be stopped down to 60mm!!
Nice CaK ones too!
Nice CaK ones too!
- Has thanked: 6305 times
- Been thanked: 7323 times
- Has thanked: 20813 times
- Been thanked: 10484 times
Lovely disks Marty! That setup works well.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Thanks Marty, lovely captures despite it being a quiet sun.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4427 times
Great shots Marty...well done
Well done Marty, these are lovely full discs good seeing will come soon
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Very nice disks
Marios S.Ioannou
Sketcher/Visual Observer
