February 2 2021. WL Only
- Has thanked: 17572 times
- Been thanked: 16694 times
Everyone,
I observed just for a few minutes around 4:30pm. Today has mostly been cloudy and areas just north of me are blanketed in 5 inches of snow. I have none here in Edneyville. I am having to work first shift this week due to a series of meetings I am having to attend and the sun is low by the time I get home. Still some clearing occurred late and I was able to " shoot " the sun through the trees with the Orion 70mm white light solar telescope. It's cold ( 28F ) and very windy. The seeing was certainly less than perfect. I did catch a single small sunspot in the NW that was at the SW end of a patch of faculae. I can also easily see another patch of faculae west-southwest of the spot near the limb. I could just hint the granulation. The magnifications used are 25x and 50x.
Carpe Noctem!
Carpe Noctem!
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: February 2 2021. WL Only
Thanks James, lovely capture despite the weather. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Stardust5858 wrote: ↑Wed Feb 03, 2021 1:52 am Thanks James, lovely capture despite the weather. Thanks for sharing.
You are welcome. I thought I was gonna miss out. The Sun is starting to climb a bit higher in the sky. It's becoming noticeable now.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Thanks you James. Lovely!
Marios S.Ioannou
Sketcher/Visual Observer
Thanks and you are welcome Marios.
Cheers James and the SDO image shows just the one spot then and still is just one today.
Thanks vm
Thanks vm
- Been thanked: 8792 times
- Has thanked: 20442 times
- Been thanked: 10247 times
Nice report James, i'v e scheduled a work at home day on Thursday with the forecast of some blue skies, we will see! Sounds like you just missed out on the weather there.
Your weather maybe similar to the current weather in Scotland where much more snow has fallen and causing some problems, but here in the S.E.England for the third time lately, snow is forecast for this weekend, but so far other than a brief Sleet, nothing has occurred around my home town. In the county though some has fallen without known disrutptions.
Thanks again for your daily report James and AR2801 has no spot at around 2000Z TODAY (Wednesday)...
tERRY
tERRY
I tried to get the Sun this evening ( 2-3-21 ) after work around 4:45 to 5:00pm but had little success. Using the Coronado SMII60 I could with certainty see only one prominence. The seeing was horrible with the sun being so low and it was in the trees so I was viewing through a considerable amount of intervening limbs in the way. Working 2nd shift certainly has it's advantages with solar observing since I am usually home when the sun is higher in the sky. If I worked days it would decimate my solar observation program in the winter months.
You have done exceedingly-well of the last few months James for a working person and when eventually you are able to retire (like me) you may well appreciate that you have a tad more time to Solar-observe (in between finding many more jobs to do, keeping you as busy as ever)...
I know that for sure, even though I spent 10-years flying nearly every day after work-retirement, but at least keeps the "brain-box" ticking-over - well...
I am not the only often-posting-observer. Pedro Re, Eric Roel and Rainer are also very often posting their sessions. They don't only post very often but usually have generally good weather conditions too. But are all three of them retired? In a meeting Stephen Ramsden said he liked quality over quantity and these three excel. But there are a lot of excellent imager/observers here on SolarChat. I am blessed to be here in such company!
That is correct James and when those you mentioned have clear skies, then we get the best images of the action and in some cases - even if their weather is perfect, they still produce the best images.
In fact when Pedro doesn't post images, one can tell that for a rare-change he's weather if not good...
As you correctly add, thanks to the many excellent other imagers here on SolarChat, is the chance to learn by their fab images...
Cloudy today over Edneyville. No direct solar viewing for me. I'll have to rely on you guys and gal and SDO and GONG.
Sorry to say James that you didn't miss much to tell us, but hey, hope you had a good day otherwise..
Yeah it went well. I have worked with engineers, technicians and engineer co-op trainees all week. It's been a learning experience. Next week I will be back to my normal second-shift evening hours. Solar will be easier. But I picked a good week to work first shift. It's been largely cloudy.EGRAY_OBSERVATORY wrote: ↑Thu Feb 04, 2021 10:31 pm Sorry to say James that you didn't miss much to tell us, but hey, hope you had a good day otherwise..
Sounds well-interesting then James.
I had the same experiences when starting to work with HeavyLift Cargo Airlines/Engineering Division a few years back. Learnt much and had lots to do throughout any 24-hour period. Worked on some very large aircraft types, with one at least still around in Cairns, Australia.
Those were the days...
