Clouds and a light wind. Clear.
Rumak180 PSTMod2 Clave 25mm
10.15 BST
5.00 CT 7.30 Tall prom like a spoon, arc down to a shorter bright prom leaning away 60deg.
4.15 CT 8.45 Two groups of two proms. Stubby sprays.
11.00 CT 1.00 A square rectangle with body going away like a US covered bridge. Bright spike to right.
11.30 BST
2.30 CT 10.00 Faint prom looks like an angel.
3.05 BST
5.30 Hollow leaning down prom with a faint spray seperated and leaning up more.
5.00 CT 7.30 Bright jet leaning right 20deg. Faint seperated prom to left, thin prom next to it and then a C shaped prom.
4.30 Little seperated jet
4.00 CT 8.45 Little exclamation mark to right Y shaped prom with top brighter. Top horizontal connection to a hand mirror shaped prom. Gap to another jet from surface.
3.00 An open vertical oval with a thumb prom above. Below a jet seperated from surface.
11.00 CT 1.00 Central bright prom, upturned apostrophe leaning right. Bright base. To left stumpy jet leaning left 20deg with arch from top towards centre prom. On right a little short jet.
8.30 CT 4.30 Diffuse spray of 3 oval proms.
7.00 CT 5.00 Little pyramid prom than gap to a jet leaning right 60deg.
Cheers. Andrew.
Visual Report 11/04/2021
- Has thanked: 3292 times
- Been thanked: 1887 times
- Been thanked: 16693 times
Re: Visual Report 11/04/2021
Very nice detailed descriptions, Andrew!
- Has thanked: 20424 times
- Been thanked: 10243 times
Thanks for the report Andrew!
