Dynamic prominence on the eastern edge.
- oreoluna
- Been thanked: 661 times
Hello everyone.
Yesterday I was able to observe this magnificent prominence on the eastern edge.
Prom on NE edge ....................................................................Spicules Off-Band
AR2814 in Line .......................................................................Off-Band
LZOS 6" f8 Apo, Baader D-ERF 160, TV 4x Powermate, SolarSpectrum 0.3 À, ASI290mm
CS Jozef
CS Jozef
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Re: Dynamic prominence on the eastern edge.
Nice,
What type of solar setup do you have. Thanks
Magnus
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Has thanked: 9327 times
- Been thanked: 6163 times
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Wonderful set of images Jozef.
David
David
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Been thanked: 8907 times
These are incredible Jozef, the Sun is putting on a very good show
- Been thanked: 4881 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Fantastic set of image's Jozef, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17860 times
- Been thanked: 17004 times
I noticed this on the GONG image at the time but clouds and being busy kept me from setting up to observe it. It's massive and your images of it are great!!
- Been thanked: 4981 times
- Has thanked: 8559 times
- Been thanked: 8297 times
Superb images, Jozef. Very impressive.
Absolutely impressive Jozef, showing a beautiful coloured giant prom..
Thanks for sharing
Thanks for sharing
- Been thanked: 4434 times
Incredible set of images Jozef
Excellent capture and processing for these indeed.
