AR12814 and AR12815 - April 17, 2021
- Has thanked: 9144 times
- Been thanked: 6025 times
Hello everybody: today not an easy day for solar imaging. Mostly cloudy here with 3 to 5 second gaps between the clouds and poor seeing conditions on top. I was able to take a close up of AR2814 and AR2815 but it needed a lot of processing to get anything out of a very flat stacked image.
- Cloudy sky.jpg (703.08 KiB) Viewed 548 times
- 091225 final mono.jpg (861.42 KiB) Viewed 548 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: AR12814 and AR12815 - April 17, 2021
Well done under the circumstances.
Dan
South central Indiana
USA
USA
- Has thanked: 146 times
- Been thanked: 277 times
Well gosh Franco. Despite clouds and poor seeing you managed to put together a very nice image. You must have had some moments of better than poor seeing. It looks like you are using an SCT. What type of Ha filter?
Hi David: thank you. This is the stacked unprocessed image saved in PNG format. The scope is the HaT scope and the filter is the Solar Spectrum that finally came home after a very long time out for repair.
- Sun_091325_g6_ap10988.png (3.09 MiB) Viewed 536 times
- IMG_3391.jpg (936.85 KiB) Viewed 536 times
- 091325 final mono inverted.jpg (830.84 KiB) Viewed 536 times
- Been thanked: 16693 times
Franco,
These turned out good considering what you had to look through. An AiryLab/Celestron HaT! Awesome!!
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Nice kit franco, shame about the seeing. So frustrating when the seeing does not cooperate.
Looks like you are going to have fun when the seeing does you a favour.
David
David
- Has thanked: 8415 times
- Been thanked: 8161 times
Really excellent, Franco, especially under such challenging circumstances.
- Been thanked: 4786 times
Well done under the circumstances, lovely details to see Franco.
Thank you all for your nice comments. @James: yes, I like this set up. When the conditions are favorable it produces good results, but the seeing reduces the opportunities to use it.
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Franco, a very beautiful photo, especially the last one, where the image is inverted. It looks like fur or velvet.
Hello Franco, you have certainly done so well in those challenging conditions to produce such an excellent images.
Similar cloud formation here today, but hey-ho !! That's what all astronomers/Solar-observers/imagers have to endure...
Thanks for sharing
Regards
Thanks for sharing
Regards
- Been thanked: 4340 times
Great image Franco
You managed to pull out a sharp image despite the conditions...well done!!!
Thank you Ivan, Terry and Brian for your kind words.
- Has thanked: 9401 times
- Been thanked: 5565 times
Hi Franco,
Very well done.
Very well done.
- Been thanked: 4904 times
Franco:
You got the shots you could do, sometimes we forget how difficult is to deal with those weather conditions when imaging.
Well done.
Well done.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Fine images, Franco, the setup seems working fine, just wait for a better seeing.
Lot of wires above your head, almost disturbing as the clouds
Raf
Thanks a lot Rainer, Eric and Raf, greatly appreciated.
- Been thanked: 2713 times
Hi Franco,
Just wondering what is your feed back on the slar guider ? Are you happy with it for high resolution imaging ?
Thanks !
Christian
Thanks !
Christian
Hi Christian: yes, I think the Hinode guider helps a lot at high magnification to keep the image steady. It also has a very useful sound Sun proximity feature that make it very easy to point a large scope. I use it with all my scopes except the Lunt 50.
