April 19th 2021 - Lots of goodies!
Simon2940
Has thanked: 1071 times
Been thanked: 1985 times
Post by Simon2940 »
Seeing was on point today so i went on a capturing spree and ran out of drive space.
Esprit 150 with Daystar Gemini in Chrom mode and the Lunt Herschel Wedge for white light.
Mosaic 01.jpg (1.52 MiB) Viewed 410 times
Mosaic 03.jpg (1.73 MiB) Viewed 410 times
Full Pan.jpg (623.98 KiB) Viewed 410 times
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Re: April 19th 2021 - Lots of goodies!
Post by p_zetner »
Very nice set, Simon.
Peter
rcwinter
Has thanked: 191 times
Been thanked: 265 times
Post by rcwinter »
Wow, really nice set of images < I would like get images that show the surface detail and proms , do you overlay or something like that, still trying to figure out how to do that
Brilliant set , thanks for sharing
Rich
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
Astrophil
Been thanked: 581 times
Post by Astrophil »
Those are great Simon. You might consider a larger drive for days like this one.
Has thanked: 17666 times
Been thanked: 8787 times
These are gorgeous :bow :hamster: I really must try and process some I took at the weekend otherwise my drive will be filling up ;)
Has thanked: 8415 times
Been thanked: 8161 times
Post by Carbon60 »
Very nicely done, Simon. Great images.
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Lovely captures Simon. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Simon2940
Post by Simon2940 »
The images that show surface and proms are not overlays or composite images. They are shot and processed as is.
Shooting in 16 bit (ASI174MM is actually only getting 12 bit) allows you to see more than what is there. The processing that i use allows for both to show up at the same time.
rcwinter wrote: Tue Apr 20, 2021 3:47 am Wow, really nice set of images < I would like get images that show the surface detail and proms , do you overlay or something like that, still trying to figure out how to do that
Rich
Has thanked: 17572 times
Been thanked: 16691 times
Post by DeepSolar64 »
Simon,
You not only have excellent processing skills, excellent equipment but also outstanding seeing. The mottles are resolved into spicules and your white light images are incredible with the granules clearly resolved. I am humbled by your images. Hats off to you with this wonderful set of solar goodies!!
christian viladrich
Has thanked: 1 time
Been thanked: 2712 times
Post by christian viladrich »
Very nice resolution and processing !
Has thanked: 9144 times
Been thanked: 6025 times
Post by ffellah »
Fabulous pics Simon !
Franco :bow
Ivan
Has thanked: 3465 times
Been thanked: 2250 times
Post by Ivan »
Cool photos! And how do you show prominences in chromosphere images? Do you do this in Photoshop using masks?
arnedanielsen
Has thanked: 6181 times
Been thanked: 7142 times
Post by arnedanielsen »
Wonderful set of images, Simon!
Arne
Arne
