1hr time lapse of partial disc+proms, 19th of April
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
Had a beautiful day that was finally completely cloudless (makes doing a timelaspe easier as you don't have to correct flicker/brightness variation nearly as much), and also had it off, so I got to do a lot of solar today, felt good.
This was an area I though would have more movement, but it ended up being pretty chill for the most part, but still fun to watch. I usually also color my time lapses, but this one actually had a decent amount of detail in the gradients that seemed to get crushed a bit too much when coloring, so I left it monochrome. Doesn't have that dramatic look to it that I normally like, but its easier to parse out the detail and more easily follow the movement of the little 'disc wispies' (is that a technical term?)
Lunt 100 single stack with asi294mm+bin2 and 4x telecentric with ROI of about 2100x1440, getting about 35ish fps.
Gif is forward playing only.
Lunt ls100tha single stacked + hinode solar guider on ioptron cem26 mount
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Has thanked: 9327 times
- Been thanked: 6163 times
Re: 1hr time lapse of partial disc+proms
That is a really beautiful animation ! Chromosphere and prom... well done.
- Has thanked: 977 times
- Been thanked: 345 times
Re: 1hr time lapse of partial disc+proms, 19th of April
I felt loverly and warm watching that. Thank you.
Call me Geoff.
I do what I do because I want to, and because I can....
Doesn't mean I know what I'm doing, though!
- rcwinter
- Has thanked: 191 times
- Been thanked: 265 times
Wwwooww, that's Brilliant
If only I knew how
Rich
If only I knew how
Rich
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
- AJamesB
It looks more complicated than it is. Instead of taking just one video to make a single image, you take a bunch of videos at regular intervals to turn into single images of regular intervals, batch process them to your liking then join them up in an animated series or short video using any number of programs (many of them free) to make an animation out of them. You could totally do it:)
asi178mm
asi294mm
asi178mm
asi294mm
Superb animation James.
Thanks for sharing
Thanks for sharing
- Has thanked: 8559 times
- Been thanked: 8297 times
Hi Rich,
Check out the tutorial section on this site (Library).
Here's a document that might help you.
download/file.php?id=45006
Great animation, James. Lots going on there.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely animation, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- AJamesB
This is also a good youtube tutorial by chuckastro for doing solar timelapses:
https://www.youtube.com/watch?v=VXijbjkclMc&t=1s
asi178mm
asi294mm
asi178mm
asi294mm
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
That’s a beautiful animation.
I don’t think I’ve seen one that includes both disk and proms before.
Well done.
Peter
Well done.
Peter
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7327 times
Beautiful animation, James. Thanks for sharing!
Arne
Arne
- Ivan
- Has thanked: 3489 times
- Been thanked: 2267 times
Wow, a boiling sunny ocean and fireworks! Amazing! Thank you for sharing.
- Has thanked: 17859 times
- Been thanked: 17003 times
JamesB,
Very nice to watch. It runs smooth and is evenly lit. Very natural and has a lot of detail.
JamesP
JamesP
- Has thanked: 20828 times
- Been thanked: 10501 times
Excellent!
- AJamesB
Much of that credit goes not to my capture ability but to the tools available in Davinci Resolve, a video editor I've been learning the last few weeks. It has deflicker/brightness normalization, frame rate increase/interpolation, incredible stabilzation, the ability to process images in spite of being a video editor, and other tools that really make up for my lack of attention to detail in the capture process, lol. It amazes me what software and tech can do these days!DeepSolar64 wrote: ↑Mon Apr 26, 2021 1:45 am JamesB,
JamesP
asi178mm
asi294mm
asi178mm
asi294mm
