1hr time lapse of partial disc+proms, 19th of April
AJamesB
Has thanked: 1154 times
Been thanked: 630 times
Post by AJamesB »
Had a beautiful day that was finally completely cloudless (makes doing a timelaspe easier as you don't have to correct flicker/brightness variation nearly as much), and also had it off, so I got to do a lot of solar today, felt good.
This was an area I though would have more movement, but it ended up being pretty chill for the most part, but still fun to watch. I usually also color my time lapses, but this one actually had a decent amount of detail in the gradients that seemed to get crushed a bit too much when coloring, so I left it monochrome. Doesn't have that dramatic look to it that I normally like, but its easier to parse out the detail and more easily follow the movement of the little 'disc wispies' (is that a technical term?)
Lunt 100 single stack with asi294mm+bin2 and 4x telecentric with ROI of about 2100x1440, getting about 35ish fps.
Gif is forward playing only.
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
Has thanked: 9297 times
Been thanked: 6131 times
Re: 1hr time lapse of partial disc+proms
Post by ffellah »
That is a really beautiful animation ! Chromosphere and prom... well done.
Alto
Has thanked: 962 times
Been thanked: 334 times
Re: 1hr time lapse of partial disc+proms, 19th of April
Post by Alto »
I felt loverly and warm watching that. Thank you.
Call me Geoff.
rcwinter
Has thanked: 191 times
Been thanked: 265 times
Post by rcwinter »
Wwwooww, that's Brilliant :bow :bow
If only I knew how
:bow2 :bow2 :bow2
Rich
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
AJamesB
Post by AJamesB »
rcwinter wrote: Tue Apr 20, 2021 11:12 am
If only I knew how
Rich
It looks more complicated than it is. Instead of taking just one video to make a single image, you take a bunch of videos at regular intervals to turn into single images of regular intervals, batch process them to your liking then join them up in an animated series or short video using any number of programs (many of them free) to make an animation out of them. You could totally do it:)
asi178mm
asi294mm
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Superb animation James.
Thanks for sharing
Has thanked: 8523 times
Been thanked: 8256 times
Post by Carbon60 »
rcwinter wrote: Tue Apr 20, 2021 11:12 am Wwwooww, that's Brilliant :bow :bow
If only I knew how
:bow2 :bow2 :bow2
Rich
Hi Rich,
Check out the tutorial section on this site (Library).
Here's a document that might help you.
download/file.php?id=45006
Post by Carbon60 »
Great animation, James. Lots going on there.
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Lovely animation, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
AJamesB
Post by AJamesB »
This is also a good youtube tutorial by chuckastro for doing solar timelapses:
https://www.youtube.com/watch?v=VXijbjkclMc&t=1s
asi178mm
asi294mm
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
That’s a beautiful animation.
I don’t think I’ve seen one that includes both disk and proms before.
Well done.
Peter
Fed
Oh, I get it now!
Oh, I get it now!
Has thanked: 18 times
Been thanked: 23 times
Post by Fed »
That is quite something!
arnedanielsen
Has thanked: 6276 times
Been thanked: 7295 times
Post by arnedanielsen »
Beautiful animation, James. Thanks for sharing!
Arne
Arne
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Wow, a boiling sunny ocean and fireworks! Amazing! Thank you for sharing.
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
JamesB,
Very nice to watch. It runs smooth and is evenly lit. Very natural and has a lot of detail.
JamesP
Has thanked: 20756 times
Been thanked: 10442 times
Excellent!
AJamesB
Post by AJamesB »
DeepSolar64 wrote: Mon Apr 26, 2021 1:45 am JamesB,
JamesP
Much of that credit goes not to my capture ability but to the tools available in Davinci Resolve, a video editor I've been learning the last few weeks. It has deflicker/brightness normalization, frame rate increase/interpolation, incredible stabilzation, the ability to process images in spite of being a video editor, and other tools that really make up for my lack of attention to detail in the capture process, lol. It amazes me what software and tech can do these days!
asi178mm
asi294mm
