Hi Everyone.
After a snow dump on Saturday night / Sunday morning, skies cleared to a beautiful morning on Monday with Astrospheric predicting better than average seeing. I set up the C8 and took a few higher resolution shots of three regions on the Sun shown in the NSO picture below, a larger faint prom and active regions 12816 and 12817. Sorry about the random orientations of the images! On Monday, AR12817 was apparently not a full-fledged active region with a (SDO) designation of S6825. Unfortunately, I missed the filaprom which a number of you imaged beautifully. The seeing was along the lines of the Astrospheric prediction; moments where it was above average. After packing up my gear, the clouds rolled in with more snow flurries and they are still falling as I post this!
Shots were taken with the Celestron C8, Aries ERF, ~4.6x telecentric, Daystar 0.6A QPE, ~0.65x focal reducer and Pt. Grey Grasshopper (IMX174 cmos). The effective focal length was about 6 metres.
Peter
H alpha from 19 April.
- Has thanked: 2467 times
- Been thanked: 4881 times
- Has thanked: 9335 times
- Been thanked: 6164 times
Re: H alpha from 19 April.
Excellent images Peter ! Tremendous action in the second one, very well captured.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Thanks, Franco!
I also tried imaging at f46 (9.2 metres focal length) but the seeing really didn't support it. Here is the smaller AR in normal and inverted versions at this image scale. I wasn't going to post these but maybe they have some artistic charm!
Peter.
Peter.
- Has thanked: 20836 times
- Been thanked: 10504 times
Nice set Peter!
How often do you have to collimate the scope? Do you have any issues with image shift with your SCT when focusing?
- Been thanked: 4434 times
A great set of images Peter, well done
