April, 20 Ca K images with Barr + Alluxa stack and TOA 150
- Been thanked: 2725 times
Hello,
Yesterday, I was blessed by spells of good seeing thank to windy conditions. The Barr + Alluxa stack is definitely a killer in Ca K.
The ASI 1600 is another killer for Ca K FD images:
http://astrosurf.com/viladrich/astro/so ... SI1600.jpg
The view of AR2816 was great:
http://astrosurf.com/viladrich/astro/so ... ASI290.jpg
Unfortunatly, seeing got worse when I went to AR2817. Sill the view of the flare and some fibrils was great :
Clear skies !
Clear skies !
- Has thanked: 977 times
- Been thanked: 345 times
Re: April, 20 Ca K images with Barr + Alluxa stack and TOA 150
Wonderful!
Call me Geoff.
I do what I do because I want to, and because I can....
Doesn't mean I know what I'm doing, though!
Excellent captures Christian - thanks for sharing
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Spectacular images, Christian!
The high resolution results are amazing.
Are you doing your imaging at Pic du Midi?
Peter
Peter
- Has thanked: 8559 times
- Been thanked: 8297 times
Excellent, Christian. That’s an exceptional setup under optimal conditions.
- rcwinter
- Has thanked: 191 times
- Been thanked: 265 times
Wow, just awesome images and setup
Amazing detail
Rich
Amazing detail
Rich
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
- Has thanked: 1314 times
- Been thanked: 64 times
Those are fantastically good images. Congratulations
John
John
- Has thanked: 20834 times
- Been thanked: 10503 times
Yup! That works
Is that 0.8ms exposure time running on minimum gain with the ASI?
*edit - ignore me - can see the gain values on the image footer*
- Been thanked: 4434 times
Outstanding images Christian
The filter set sure perform very, very well!
- Has thanked: 2464 times
- Been thanked: 4881 times
- Has thanked: 1277 times
- Been thanked: 1070 times
Splendid work, Christian, absolutely top notch!
which barlow or telecentric was used for closeups?
regards
Leo
regards
Leo
- Has thanked: 9327 times
- Been thanked: 6163 times
These are totally great Christian. Super detailed images.
- Been thanked: 8907 times
Oooohhhh what a beauty to behold, I could stare at these all day
Thanks to all !
Peter, the images are taken from my garden. This summer, I'll go to St Véran.
Leo, I use Baader FFC at about 3.2x. Maybe Baader TZ-3 could be a good idea too. I'll see if I can get one for a test.
Christian
Christian
I wondered how you were getting this image scalechristian viladrich wrote: ↑Thu Apr 22, 2021 6:47 pm I use Baader FFC at about 3.2x. Maybe Baader TZ-3 could be a good idea too. I'll see if I can get one for a test.
You should give Freds 2.79x telecentric a try at CaK, I find it a brilliant piece of glass down in the blue. I'd be interested to see how you got on with it, and how it compares to the FFC.
- Has thanked: 17863 times
- Been thanked: 17007 times
I have never heard of Barr Associates filters. Wonderful high rez images too!!
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7327 times
Fantastic work Christian!
Arne
Arne
This could be an idea worth trying. Thanks Mark.marktownley wrote: ↑Sat Apr 24, 2021 8:13 amI wondered how you were getting this image scalechristian viladrich wrote: ↑Thu Apr 22, 2021 6:47 pm I use Baader FFC at about 3.2x. Maybe Baader TZ-3 could be a good idea too. I'll see if I can get one for a test.
Barr Associates was bought by Materion Precisions some years ago. Their commecial policy changed and their prices skyrocketed ...DeepSolar64 wrote: ↑Sat Apr 24, 2021 9:51 am I have never heard of Barr Associates filters. Wonderful high rez images too!!
That's a shame. It will probably cost them valuable customers.christian viladrich wrote: ↑Fri Apr 30, 2021 8:03 amBarr Associates was bought by Materion Precisions some years ago. Their commecial policy changed and their prices skyrocketed ...DeepSolar64 wrote: ↑Sat Apr 24, 2021 9:51 am I have never heard of Barr Associates filters. Wonderful high rez images too!!
For information, here is a picture of the focus assembly:
http://astrosurf.com/viladrich/astro/in ... onomik.jpg
