April, 20 Ca K images with Barr + Alluxa stack and TOA 150
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Hello,
Yesterday, I was blessed by spells of good seeing thank to windy conditions. The Barr + Alluxa stack is definitely a killer in Ca K.
The ASI 1600 is another killer for Ca K FD images:
http://astrosurf.com/viladrich/astro/so ... SI1600.jpg
The view of AR2816 was great:
http://astrosurf.com/viladrich/astro/so ... ASI290.jpg
Unfortunatly, seeing got worse when I went to AR2817. Sill the view of the flare and some fibrils was great :
Clear skies !
Alto
Has thanked: 962 times
Been thanked: 330 times
Re: April, 20 Ca K images with Barr + Alluxa stack and TOA 150
Post by Alto »
Wonderful!
Call me Geoff.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Excellent captures Christian - thanks for sharing
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Spectacular images, Christian!
The high resolution results are amazing.
Are you doing your imaging at Pic du Midi?
Peter
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Excellent, Christian. That’s an exceptional setup under optimal conditions.
DavidP
Has thanked: 147 times
Been thanked: 290 times
Post by DavidP »
Amazing sharp detail. Well done
rcwinter
Has thanked: 191 times
Been thanked: 265 times
Post by rcwinter »
Wow, just awesome images and setup
Amazing detail
Rich
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
John
Has thanked: 1313 times
Been thanked: 64 times
Post by John »
Those are fantastically good images. Congratulations
John
Has thanked: 20738 times
Been thanked: 10439 times
Yup! That works :cool:
Is that 0.8ms exposure time running on minimum gain with the ASI?
*edit - ignore me - can see the gain values on the image footer*
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Outstanding images Christian :bow
The filter set sure perform very, very well!
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Excellent Christian.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
LeoD
Has thanked: 1277 times
Been thanked: 1070 times
Post by LeoD »
Splendid work, Christian, absolutely top notch!
which barlow or telecentric was used for closeups?
regards
Leo
Has thanked: 9294 times
Been thanked: 6128 times
Post by ffellah »
These are totally great Christian. Super detailed images.
Franco :bow
Has thanked: 17925 times
Been thanked: 8891 times
Oooohhhh what a beauty to behold, I could stare at these all day :bow :bow :bow
christian viladrich
Has thanked: 1 time
Thanks to all !
Peter, the images are taken from my garden. This summer, I'll go to St Véran.
Leo, I use Baader FFC at about 3.2x. Maybe Baader TZ-3 could be a good idea too. I'll see if I can get one for a test.
Christian
christian viladrich wrote: Thu Apr 22, 2021 6:47 pm I use Baader FFC at about 3.2x. Maybe Baader TZ-3 could be a good idea too. I'll see if I can get one for a test.
I wondered how you were getting this image scale ;)
You should give Freds 2.79x telecentric a try at CaK, I find it a brilliant piece of glass down in the blue. I'd be interested to see how you got on with it, and how it compares to the FFC.
Has thanked: 17813 times
Been thanked: 16950 times
Post by DeepSolar64 »
I have never heard of Barr Associates filters. Wonderful high rez images too!!
arnedanielsen
Has thanked: 6276 times
Been thanked: 7294 times
Post by arnedanielsen »
Fantastic work Christian!
Arne
Arne
christian viladrich
Has thanked: 1 time
marktownley wrote: Sat Apr 24, 2021 8:13 am
This could be an idea worth trying. Thanks Mark.
christian viladrich
Has thanked: 1 time
DeepSolar64 wrote: Sat Apr 24, 2021 9:51 am I have never heard of Barr Associates filters. Wonderful high rez images too!!
Barr Associates was bought by Materion Precisions some years ago. Their commecial policy changed and their prices skyrocketed ...
christian viladrich wrote: Fri Apr 30, 2021 8:03 am
That's a shame. It will probably cost them valuable customers.
christian viladrich
Has thanked: 1 time
For information, here is a picture of the focus assembly:
http://astrosurf.com/viladrich/astro/in ... onomik.jpg
