Today is my first fully-operational observatory captures today and I have started using some of the Barlows - during a very-clear skies day.
A little turbulence as also quite breezy-winds, but hey can't have everything all the time...
Enjoy..
22-4-2021 AR2818,2817,2816 in three lights
- 22-4-2021 1247z Ha.jpg (228.31 KiB) Viewed 105 times
- 22-04-20211248z Ha.jpg (299.09 KiB) Viewed 105 times
- 22-04-2021 1140z Calcium-K.jpg (754.83 KiB) Viewed 105 times
- 22-4-2021 1244z Calcium-K.jpg (602.72 KiB) Viewed 105 times
- 22-4-2021 1225Z WL AR2817 with TELEVUE 2•5x Powermate.jpg (11.65 KiB) Viewed 105 times
- 22-4-2021 1226z AR2818 WL + TELEVUE 2•5x Powermate.jpg (56.47 KiB) Viewed 105 times
- 22-4-2021 1327z WL AR2818, 2817, & 2816.jpg (25.26 KiB) Viewed 105 times
- SDO 22-4-2021 PM latest_512_HMII.jpg (27.33 KiB) Viewed 105 times
- Been thanked: 8793 times
Re: 22-4-2021 AR2818,2817,2816 in three lights
Great work Terry glad to see you finally up and running in the observatory and enjoying the rays
How are the eyes? I hope you are on the road to recovery now.
- Been thanked: 10248 times
Looks like you had a good run of images Terry!
Thank you Mark and seeing my images again, I should be able to improve significantly in future.
Hi Alexandra, the original problem with one-eye has responded-well to the treatment from the hospital, but a Cataract-op is required for the other eye and probably both will be done - as and when.
I certainly do have some difficulty with the smaller PC screen that is used for processing and looking at the posts etc., which no-doubt are affecting the processed image results. I will have to start using the observatory's large-screens to do that processing...
Now that four Sun-spot groups could be around for a while, I must try again.
