Hi All,
I realise that in the past 2 years, there was little to image on the sun. Now the sun is coming to life, I have managed (with advice from you all) to improve my technique and imaging.
Today, I was trying to adjust my ZWO tilt adjuster to reduce or eliminate Newton Rings, but after over 1 hour, I gave up. I then used Firecapture to capture data, and was making progress (with flat field calibration), I was starting to do a full disc with over 10-15 images (I have not counted yet), and the last few panes was affected by tree branches blocking the sun !!
Anyway, I think there is more cloud coming up, so maybe there is plenty of time to do solar later in the year.
I did a quick process of one of the images (there are total 100 GB from 2 days imaging).
I think NRs are mostly removed but still affect my resolution and detail. NR are removed with ImageJ. I am now waiting for a GSO focuser and ASI174mm all the way from USA. Maybe the 1.40 USD exchange rate will work in my favour despite the postal fee of 50 USD.
I may get the Daystar eliminator if I get NRs with the ASI174 camera.
Quark Chromosphere/ED70/0.5x focal reducer/ASI120mm-S/AS!3/ImageJ/ImPPG/Photoshop
Thanks for looking.
Magnus
The Sun 22nd April 2021
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Re: The Sun 22nd April 2021
That's an excellent pair of images Magnus - showing so much detail.
Well done and thanks for sharing
- JochenM
- Been thanked: 1619 times
Looks good, Magnus.
I'm unfamiliar with the ASI120. In my case, the sweet spot on the tilting adapter (with an ASI174) is the most minor of tilts (just a small nudge of its non-tilted position), which removes the NR's completely. So once you get the ASI174, it should be fairly easy to solve.
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Lovely Magnus.
I suffer from NRs and abandoned my tilt adapter. I found it too fiddly especially when the NRs only
seemed to appear when I pushed the processing. I had reasonable success with plastic bag flats and more so
with allowing drift ( if possible ). If all else fails I use the FFT solution in ImageJ/Fiji but that is not always easy.
NRs are a big pain.
David
NRs are a big pain.
David
Fantastic activity on just a small area of the disc, what a shot!! Newton's rings are the biggest pain in Halpha
- Been thanked: 10489 times
Nice shots, interesting about the exchange rate...
