Animation - AR12816 Flare- new/improved...
- Has thanked: 8558 times
- Been thanked: 8290 times
Captured this morning over a period of 1hr (each frame separated by 2 minutes).
Start 08:33 UTC
Interesting to see the flare progress like a lightning bolt threading through the magnetic loops.
A bit 'flickery' and there's a bit of image rotation.... but hey....
Animation: Active Region 12816 flaring 22nd April by Stuart Green, on Flickr
Thanks for looking.
Start 08:33 UTC
Thanks for looking.
Re: Animation - AR12816 Flare
That's a dramatic reconstruction of the events that AR2816 is doing, so thanks vm for sharing the excellent animation.
Regards
Regards
- Has thanked: 9319 times
- Been thanked: 6157 times
Great work Stu: first time I see it spreading like this.
Congratulations on the beautiful SPOD: very well deserved.
- JochenM
- Been thanked: 1619 times
- Ivan
- Has thanked: 3483 times
- Been thanked: 2262 times
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Terrific work !
What size solar scope do you have ?
Magnificent !
Magnus
Magnificent !
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Wicked animation Stu, love that!
David
David
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely animation Stu, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Fabulous!! what luck the lightning zipps right across the AR in a flash.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Fine animation, Stu, very sharp.
Raf
- Has thanked: 17853 times
- Been thanked: 16992 times
Literally " a flash "!
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
Wow, fantastic detail, love it!
I've recently been exploring video editor software in regards to doing animations. In Davinci Resolve, there are some easy ways (once you learn Davinci's quirky work flow) of removing all rotating, flickering, etc., as well as interpolating the frames into a higher frame rate. If ya like I can run this through my workflow really quickly to show you what I mean.
Great images though, thanks for sharing!
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hi Stu.
I think you’ve captured an example of a “two-ribbon” flare. Some quick investigation via “The Google” shows observations that are similar to yours. For example: https://www.on.kitp.ucsb.edu/online/so ... etcher.pdf
Peter
Peter
Hi Magnus,
It’s a 150mm mod based on Lunt 35 etalons. It works out at f14 native.
Stu
Thanks, James. I’ll take a look. Thanks for the information and offer.AJamesB wrote: ↑Sat Apr 24, 2021 1:46 am Wow, fantastic detail, love it!
That’s great information, Peter. Thanks for the link. Much appreciated.p_zetner wrote: ↑Sat Apr 24, 2021 2:05 am Hi Stu.
Peter
- Has thanked: 20813 times
- Been thanked: 10487 times
Very impressive indeed Stu!
Many thanks, Mark.
Here’s a reworked version, with better balance of brightness and contrast between frames.
AR12816_Animation_Flare by Stuart Green, on Flickr
Stu
Stu
