April 23 ...
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
April 23 ...
Post by MAURITS »
This morning was one of the better for the sun shots.
I used only my Quark Prominence filter.
ASI 174MM without reducer.
ASI 290MM with reducer.
ASI174MM without reducer.
094749 Gray Earth.jpg (559.69 KiB) Viewed 341 times
095002 Gray.jpg (663.41 KiB) Viewed 341 times
100528 Gray.jpg (656.2 KiB) Viewed 341 times
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
DJD
Has thanked: 42 times
Been thanked: 133 times
Re: April 23 ...
Post by DJD »
Excellent set Maurits.
Beautiful.
David
Has thanked: 17894 times
Been thanked: 8887 times
Re: April 23 ...
Wow!! what a set :bow :hamster: truly beautiful :bow
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Re: April 23 ...
Post by JochenM »
That came out great, Maurits.
Jochen Maes
Belgium
https://www.jochenmaes.com
Has thanked: 17807 times
Been thanked: 16943 times
Re: April 23 ...
Post by DeepSolar64 »
WoW Maurits! Nice high-rez work. Beyond anything I have ever imaged or seen visually. BIG thumbs up!!
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: April 23 ...
Post by EGRAY_OBSERVATORY »
Very nice Maurits. in fact excellent captures with the very-clear blue sky that we both have at present.
Thanks for sharing
Regards
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Re: April 23 ...
Post by p_zetner »
Beautiful shots, Maurits!
Peter
AndiesHandyHandies
Has thanked: 3304 times
Been thanked: 1902 times
Re: April 23 ...
Post by AndiesHandyHandies »
I was having a bit of a technical day trying baffles and using that prom. 127mm Triplet, Baader UV-IR, 4.2x and Chromo Quark and Clave' 25mm after starting with Meade 32mm.
It looked like a face and later on of a sheep or fish to me. I saw quiet a few dark holes in the prom contributing to that.
And some fine structure.
Eye quiet a pronounced dark hole. Longer hole as a nose. and a fuzzy hole mouth over a bright chin which matches your brighter feature on one side. At one point there was a small fish like barb under the chin.
I could see the dark spot but no surface details like your image.
I tried adding my Baader 35nm and Beloptik KG3 from my PST Mod to the eyepiece and the temperature measured looking down the eyepiece only went down 0.2C so pretty much the same IR blocking as in the Quark I presume. Re-assuring.
Cheers. Andrew.
Has thanked: 9280 times
Been thanked: 6125 times
Re: April 23 ...
Post by ffellah »
Fantastic shots, Maurits. I was just out with the Lunt 50 and saw that awesome triangular prom: what a sight !
Re: April 23 ...
ffellah wrote: Fri Apr 23, 2021 10:12 pm Fantastic shots, Maurits. I was just out with the Lunt 50 and saw that awsome triangular prom: what a sight !
It was. My Coronado 60 showed it very well too!
Been thanked: 10432 times
Re: April 23 ...
These are brilliant Maurits!
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Re: April 23 ...
Post by marios i. »
Lovely!
Marios S.Ioannou
Sketcher/Visual Observer
