April 23 ...
April 23 ...
This morning was one of the better for the sun shots.
I used only my Quark Prominence filter.
ASI 174MM without reducer.
ASI 290MM with reducer.
ASI174MM without reducer.
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Re: April 23 ...
Excellent set Maurits.
Beautiful.
David
Beautiful.
David
- Has thanked: 17970 times
- Been thanked: 8905 times
- JochenM
- Been thanked: 1619 times
- Has thanked: 17845 times
- Been thanked: 16977 times
Re: April 23 ...
WoW Maurits! Nice high-rez work. Beyond anything I have ever imaged or seen visually. BIG thumbs up!!
Re: April 23 ...
Very nice Maurits. in fact excellent captures with the very-clear blue sky that we both have at present.
Thanks for sharing
Regards
Thanks for sharing
Regards
- Has thanked: 3315 times
- Been thanked: 1907 times
Re: April 23 ...
I was having a bit of a technical day trying baffles and using that prom. 127mm Triplet, Baader UV-IR, 4.2x and Chromo Quark and Clave' 25mm after starting with Meade 32mm.
It looked like a face and later on of a sheep or fish to me. I saw quiet a few dark holes in the prom contributing to that.
And some fine structure.
Eye quiet a pronounced dark hole. Longer hole as a nose. and a fuzzy hole mouth over a bright chin which matches your brighter feature on one side. At one point there was a small fish like barb under the chin.
I could see the dark spot but no surface details like your image.
I tried adding my Baader 35nm and Beloptik KG3 from my PST Mod to the eyepiece and the temperature measured looking down the eyepiece only went down 0.2C so pretty much the same IR blocking as in the Quark I presume. Re-assuring.
Cheers. Andrew.
Cheers. Andrew.
- Has thanked: 9307 times
- Been thanked: 6144 times
Re: April 23 ...
Fantastic shots, Maurits. I was just out with the Lunt 50 and saw that awesome triangular prom: what a sight !
Re: April 23 ...
It was. My Coronado 60 showed it very well too!
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: April 23 ...
These are brilliant Maurits!
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Re: April 23 ...
Lovely!
Marios S.Ioannou
Sketcher/Visual Observer
